hey people...
located on the GOLD COAST, QLD
like the title states... wrecking r33 s2 skyline
motor, gearbox, wiring has been sold
WANT TO SALE AS WHOLE.... so any takers... i'll take $2500
otherwise after 1-2 weeks depend how many ppl want to take what..
I'll sell the parts as is below
front brakes $200 slight damage on the nissan logo... doesn't affect braking tho
rear brakes $200
complete rear end diff, shafts plus anything else $400
coil overs unsure on spring rate but nice stiff smooth ride $500
steering rack $100
front+rear swaybar $100
3" from turbo back *from memory* $300
interior
front seats $150
rear seats $100
cluster low kms.. $100
dash perfect $150
body
rear left side of the body is damaged...
but the rest is fine
Dean
Edited by 26ame
https://www.sau.com.au/forums/topic/299747-wrecking-black-r33-s2/
  • Replies 40
Hi, have you got:
Headlights
Front Bar + reo
Side Gaurds
front grill
Radiator Support
Thank you
Daniela
hey people...
rear brakes $200
steering rack $100
interior
front seats $150
rear seats $100
dash perfect $150
body
Dean
Hello, is the front bar ok? How much?
Thanks
hey people...
rear brakes $200
steering rack $100
interior
front seats $150
rear seats $100
dash perfect $150
body
Dean
What brand are the coilovers and any good for an R34GTT ?
the car had tein c spanners so I'm guessing tein..
But unsure.. I'll find out for you..
Also unsure if the coil overs will fit a r34.. I'm sure you can find some info on here tho
hi
do you have the drivers side inner guard liners ? (there the black plastic bits inside the guard above the wheel) they consist of 2 pieces per side
im after the front half that goes from under the bumper bar and up around the wheel
sounds confussing but its the best i can describe it haha
cheers
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
