ok his the situation, im running a cat back, fmic boost controller set at 12 psi and a high flow turbo stock ecu with split fire coil packs which i purchased 2nd hand in good conidition not too long ago so please dont tell me its my coil packs...only 2 days ago i got the high flow turbo put in..and im hitting bout 15psi with it on the 12psi setting and today i just started noticing the miss firing on 2nd gear round 5.5k rpm. my guess is the stock ecu is cutting it out?
any thoughts would be most appriciated.
https://www.sau.com.au/forums/topic/299763-miss-firing-55k-rpm/
2nd hand items - could be coil packs.
However running 15psi on the factory ECU is doing no favours at all. You've probably fouled the plugs, it'll do it again and again as well.
Do NOT run aftermarket turbos on the factory ECU. It is a plan for disaster and lots of issues such as what you are going through.
It will be safe to get an aftermarket ECU as R31Nismoid has said...
I get that you probably dont have the time/money for it right now or whatever the case may be - but I assure you it will be more expensive to just risk the motor... no point risking it for piss all gain at the moment anyways
what sparkplugs are you using? NGKbcp6re usualy miss after 14psi you need NGKbcp7re for higher boost and also it is prob your car hitting r&r and fouling the plugs, there no point of putting to 15psi anyway with stock ecu the car just runs shit
+ 1
the ecu cant handle it mate. if your AFM is hitting ~2.8v @ 3500rpm and ~4.1v @ 5.5rpm you will hit r&r pretty bad. turn the boost down to around 10psi and see how you go.
either way you will blow your motor by running upwards of 5.5k with a hiflow.
Edited by SECURITY
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
