Hey Guys.
Just another quick question before i bolt the new turbo in place. My factory Manifold is looking a bit worse for wear (Not leaking or anything though). Corroded away along with most of the bolts in it being stuffed. (Part of being 13 years old i guess)
Option 1 and the easiest - Leave it there pretend it isnt corroding and worry about it next time there is a problem. (maybe something could spray with to help protect the new bolts i will be putting in??)
Option 2 - Take it off (will be a nightmare i am sure) And replace it with a new Factory piece. If this is the case would it be well worth looking into ceramic coating? and would there be anything else you can do to improve the factory manifolds performance.
Option 3 - You tell me what this option is. If replacing with a non factory manifold it would have to line up like factory on both ends as well as sit in the factory location. i have ZERO interest in a himount setup.
Cheers for any help.
Luke
https://www.sau.com.au/forums/topic/299767-stock-exhaust-manifold/
Are you talking just some surface rust?
I cant imagine it being much more than that, which is nothing at all to worry about.
The manifold bolts - this is common after 10+ years. Just replace them with better studs and away you go mate.
You'll probably break a few, its easier to call a mobile thread dude to get them out - trying to do it yourself is the pits
If your super worried about the rust, get it sand blasted. Then ceramic coat it if you want it to be pretty.
I'd also port match the thing to a set of new gaskets, then clean up the casting marks etc ( on the inside ).
Edited by XRATED
Yeah its just surface. Just whilst i have access to it i might as well find out if theres a better alternative. i.e the caramic coating that will be better for me in the years to come
better in what way? :ninja:
performance - no real gains at all to coating, porting etc. Just added expense for a gain that is debatable.
It's a factory manifold which im assuming has a factory turbo (or similar small item attached).
looks - well coating or something will make it look better... but then you have a heat shield over most of it so unsure what advantage that has at the end of the day as you should always run the heat shield
Located in Bendigo Central Vic.
Thanks for answering. I shall stick with the existing manifold as it is at the moment, except with some new bolts. Yeah i still have the cover so im not fussed at all with what the manifold looks like.
Concern Solved.
Luke
Theres a tool you can get that makes it very easy
i think its called a thread puller or stud puller, can get it from repco, never know when it will come in handy
How long does it take to go back to the way it was?
6 months?
was that a question for me. if so sand blasting is a surface preperation. so all depends on if it gets coated or not.
generally most people just want the surface cleaned up and thats it.
Just wondering how long it takes before it goes back to what it was like before :rofl:
Debateable. I know there are easy outs etc.
But read the threads here about people that have attempted this alone, and ended up calling someone out the next time etc.
It costs very little per broken stud. Consensus usually seems to suggest pay the $100-$200
yeah good question, like most mild metals left uncoated they will rust, touching the steel with sweaty hands will bring
the rust on quick. i would say you would get 6-12 months on a exhaust manifold before it rusted again. but if you lived
close to salt water that could speed things up.
I charge around $40-$50 per broken stud. that's the price if you dont touch it, if you have had a go and cant get it you could be looking
at around $60 a stud depending what you have done, and if you have snapped a drill bit or easy out in there as well,expect to pay around
$100 a stud. and these prices vairy depending on the access to the stud as well.
Edited by boostn32
gotta love it when they dont tell you that they already snapped an easy out in there makes you just want to smash skulls sometimes!
So so true, only one word comes to mind when you see someting else snapped off in there, F*#K
haha yeah, thats the one word that gets said after the whole "what the f$$k, why isnt this working like normal, that should be coming out, what the f$$k is that there, Ahh F$$K" than its followed by "useless F$$king c$nts that don't know what the f**k there doing"
oh the joy of it all lmfao
Edited by Cartman
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
