Try to PM Stu Benson on here his user name is t01-100 or contact him at Octagon Tas and he will soon tell you yes-no or what needs to be changed, on a side note i pretty sure its now to late to enter, but maybe you could look at Targa Rookie Rallye, 25 & 26 APRIL 2010.
https://www.sau.com.au/forums/topic/299784-targa-specs/#findComment-4982806
well stuart checked over list, all me needs is stock rear bar/side skirts, gtr copy front bar, gtr wing, cage, seat for nav and a stock turbo with steel internals and its all good! dont think ill be able to get cage in for a while though :down:
https://www.sau.com.au/forums/topic/299784-targa-specs/#findComment-4996675
Priced up a cage for the GTR last week.
Surprising how cheap a good bolt in CAMS Approved age is these days.
Looked at something very similar to Jamies in his GTR and was only $1600 delivered.
aaah thats not bad! should fit a gtst possibly too
https://www.sau.com.au/forums/topic/299784-targa-specs/#findComment-4999138
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
