hey,
iv recently done a rb30det conversion into my r32, very budget build so the bottom end only got a new set of big end bearings, original mains and oil pump. anyway engine is up and running, runs fine, my issue lies from as soon as iv started this engine iv low oil pressure, i was running 15w40 in it, oil pressure tested at 30psi at approx 3000rpm, 15psi and idle WHEN COLD and 15psi at 3000rpm and about 2psi at idle WHEN HOT.
so i pulled the sump off, pulled out the pressure relief valve at the bottom of the oil pump, it didnt seem stuck or anything, so i cleaned it up to make sure it was sealing well, lubed up well and shimmed the spring abit to hopefully lift oil pressure.
filled with 25w50 castrol edge oil, cranked and now i cant get ANY oil pressure.
i have primed it for awhile and im not getting anything, i searched the forums and i found a thread about possibly having an air lock in the oil pump, so i as someone in that topic suggested, i cut the top off the oil filter, gutted it, filled with oil and wound the engine backward in hope to suck oil into the oil pump and get rid of the air. i didnt it for awhile, probably put atleast 2 oil filters full of oil back thru the engine and i could see it go down as i wound it.
put it back together with the 25w50 and still no oil pressure at all. iv tested with 2 different guages and im definately getting nothing.
so the engine used to have oil pressure, all i did was remove sump, remove and refit the oil relief valve (second time triple checked it was fully closed) and refitted it all again.
only thing i can think of is when i removed the sump, due to very small clearances between engine and crossmember, the guaze on the end of the oil pickup is alittle dented, nothing back at all, still clean, just not perfectly round.
any suggestions what i can check next, now im stuck....??
p.s sump is 3L sump with fins ground down
Looking forward to how you are getting on mate as ive just had the same problem with my engine.
My engine on the dyno recently lost all oil pressure and now reads nothing. Will be pulling in a few days with a hope to finding out what the issue is.
Are these engines with oil pressure problems running stock cranks and stock bearings? Do you get oil pressure back when you put your foot on the clutch?
When I first built my 30 we didn't check any clearances, just slapped it together. Turned out the crank had a heap of endfloat which destroyed the thrust washers, scored into the back of the oil pump a good 4mm or so and started to eat the webbing in the block for the main journals.
It was so bad, that you could actually see the harmonic balancer move when someone put their foot on the clutch.
Ended up pulling engine out, crank ground .010 over and a set of matching bearings went in and she was mint. Certainly learnt my lesson there :)
Mine was built by an engine reconditioner, however im not too sure now how good the job was. My engine has ACL race bearings with stock crank. I replaced the release bearing the week prior due to it being noisey, however i think that was more a problem with the engine sitting for quite sometime.
Your comments are pretty interesting though and certainly could be bang on for my setup. Will let you know once its out.
he means the thrust bearings in the engine (middle crank main), your refering to the throw-out bearing in the gearbox bellhousing.
yeah mine was just a slap together (didnt pull crank out) but i still dont see how b4 i atleast had some oil pressure, now got nothing at all...
im going to pull off my rb20 one, check it!!!! then if its ok ill put it on and see how we go
Yeah, the thrust surface on the no.4 main bearing :cool:
Mine got gradually worse (as it ate out the thrust bearing), it wasn't a sudden catastrophic failure.
So you didn't even freshen up the bottom end? just slapped your head on it?
it got new bigend bearings, but at the time i wasnt going to replace the oil pump, and the crank timing gear was seized onto the crank and i didnt want to damage the oil pump or anything in the removal process, so i just decided to leave it and hope the mains were ok.
very rarly do mains go.. unless the thust is rooted. but you will still get 60+ oil pressure when cold.
if you have only 10 or so pound the head will be very second hand very soon.
can only be a rooted oil pump or wrong bearing size.
  • 1 month later...
thanks guys,
pulled the oil pump off and it was the typical problem, the phillips head screws that hold the plate onto the back of the oil pump had come loose hence was loosing pressure.
put a genuine rb25det ($250 from usa ebay thank you!) and shes pumping again.
thanks for ur help
thanks guys,
thanks for ur help
good work i hope you loctited the new one so they dont do the same thing!
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
