hey,
iv recently done a rb30det conversion into my r32, very budget build so the bottom end only got a new set of big end bearings, original mains and oil pump. anyway engine is up and running, runs fine, my issue lies from as soon as iv started this engine iv low oil pressure, i was running 15w40 in it, oil pressure tested at 30psi at approx 3000rpm, 15psi and idle WHEN COLD and 15psi at 3000rpm and about 2psi at idle WHEN HOT.
so i pulled the sump off, pulled out the pressure relief valve at the bottom of the oil pump, it didnt seem stuck or anything, so i cleaned it up to make sure it was sealing well, lubed up well and shimmed the spring abit to hopefully lift oil pressure.
filled with 25w50 castrol edge oil, cranked and now i cant get ANY oil pressure.
i have primed it for awhile and im not getting anything, i searched the forums and i found a thread about possibly having an air lock in the oil pump, so i as someone in that topic suggested, i cut the top off the oil filter, gutted it, filled with oil and wound the engine backward in hope to suck oil into the oil pump and get rid of the air. i didnt it for awhile, probably put atleast 2 oil filters full of oil back thru the engine and i could see it go down as i wound it.
put it back together with the 25w50 and still no oil pressure at all. iv tested with 2 different guages and im definately getting nothing.
so the engine used to have oil pressure, all i did was remove sump, remove and refit the oil relief valve (second time triple checked it was fully closed) and refitted it all again.
only thing i can think of is when i removed the sump, due to very small clearances between engine and crossmember, the guaze on the end of the oil pickup is alittle dented, nothing back at all, still clean, just not perfectly round.
any suggestions what i can check next, now im stuck....??
p.s sump is 3L sump with fins ground down
Looking forward to how you are getting on mate as ive just had the same problem with my engine.
My engine on the dyno recently lost all oil pressure and now reads nothing. Will be pulling in a few days with a hope to finding out what the issue is.
Are these engines with oil pressure problems running stock cranks and stock bearings? Do you get oil pressure back when you put your foot on the clutch?
When I first built my 30 we didn't check any clearances, just slapped it together. Turned out the crank had a heap of endfloat which destroyed the thrust washers, scored into the back of the oil pump a good 4mm or so and started to eat the webbing in the block for the main journals.
It was so bad, that you could actually see the harmonic balancer move when someone put their foot on the clutch.
Ended up pulling engine out, crank ground .010 over and a set of matching bearings went in and she was mint. Certainly learnt my lesson there :)
Mine was built by an engine reconditioner, however im not too sure now how good the job was. My engine has ACL race bearings with stock crank. I replaced the release bearing the week prior due to it being noisey, however i think that was more a problem with the engine sitting for quite sometime.
Your comments are pretty interesting though and certainly could be bang on for my setup. Will let you know once its out.
he means the thrust bearings in the engine (middle crank main), your refering to the throw-out bearing in the gearbox bellhousing.
yeah mine was just a slap together (didnt pull crank out) but i still dont see how b4 i atleast had some oil pressure, now got nothing at all...
im going to pull off my rb20 one, check it!!!! then if its ok ill put it on and see how we go
Yeah, the thrust surface on the no.4 main bearing :cool:
Mine got gradually worse (as it ate out the thrust bearing), it wasn't a sudden catastrophic failure.
So you didn't even freshen up the bottom end? just slapped your head on it?
it got new bigend bearings, but at the time i wasnt going to replace the oil pump, and the crank timing gear was seized onto the crank and i didnt want to damage the oil pump or anything in the removal process, so i just decided to leave it and hope the mains were ok.
very rarly do mains go.. unless the thust is rooted. but you will still get 60+ oil pressure when cold.
if you have only 10 or so pound the head will be very second hand very soon.
can only be a rooted oil pump or wrong bearing size.
  • 1 month later...
thanks guys,
pulled the oil pump off and it was the typical problem, the phillips head screws that hold the plate onto the back of the oil pump had come loose hence was loosing pressure.
put a genuine rb25det ($250 from usa ebay thank you!) and shes pumping again.
thanks for ur help
thanks guys,
thanks for ur help
good work i hope you loctited the new one so they dont do the same thing!
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
