Ring the guys at Unique Autosports (www.nismo.com.au) - They can do a factory replacement in a tubular unit for quite a reasonable price. Or e-mail to [email protected]
I know you are in the UK, but I think you will be surprised with the price and shipping shouldn't be too much.
I have just put one on my car and it works well !
https://www.sau.com.au/forums/topic/29992-exhaust-manifolds/#findComment-609860
Thanks for the quick reply, I will give tham a shout.
Cheers
https://www.sau.com.au/forums/topic/29992-exhaust-manifolds/#findComment-609880
Buy a Jap one. The japanese have spent huge amounts of time and massive amounts of $$$ to get their manifolds working right. there is a difference - as I found out the hard way. Very expensive when you may end up having to change to a different manifold, because the one you bought isnt doing the job it is supposted to.
I have already posted a thread detailing my problems, might be worth doing a search.
https://www.sau.com.au/forums/topic/29992-exhaust-manifolds/#findComment-609970
I had my std one extrusion honed to see if it owuld make nay difference (cause I could) - but then got the one above - So I have a std manifold that has been die ground ported and extrusion honed here... doing nuthing !
https://www.sau.com.au/forums/topic/29992-exhaust-manifolds/#findComment-610589
Its pretty funny (no offence raist60) when people say I can get xxx kw from this particual part.
Thats the beauty of boost, enough will overcome alot of restriction. Just remeber VL commodores have been running 9s for a long long time - I had a discussion with a guy who owned one, thought the best way to make more power was fully port the head, bigger turbo and up the boost, then was disgusted when he had a very narrow powerband.
Same guy scoffed at the idea of bolting an RB25 head on - there is no doubting alot of power can be made with stock parts, just doesnt mean its the most efficient or 'best' way of doing things.
Just horses for courses I guess.
https://www.sau.com.au/forums/topic/29992-exhaust-manifolds/#findComment-611341
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
