Ring the guys at Unique Autosports (www.nismo.com.au) - They can do a factory replacement in a tubular unit for quite a reasonable price. Or e-mail to [email protected]
I know you are in the UK, but I think you will be surprised with the price and shipping shouldn't be too much.
I have just put one on my car and it works well !
https://www.sau.com.au/forums/topic/29992-exhaust-manifolds/#findComment-609860
Thanks for the quick reply, I will give tham a shout.
Cheers
https://www.sau.com.au/forums/topic/29992-exhaust-manifolds/#findComment-609880
Buy a Jap one. The japanese have spent huge amounts of time and massive amounts of $$$ to get their manifolds working right. there is a difference - as I found out the hard way. Very expensive when you may end up having to change to a different manifold, because the one you bought isnt doing the job it is supposted to.
I have already posted a thread detailing my problems, might be worth doing a search.
https://www.sau.com.au/forums/topic/29992-exhaust-manifolds/#findComment-609970
I had my std one extrusion honed to see if it owuld make nay difference (cause I could) - but then got the one above - So I have a std manifold that has been die ground ported and extrusion honed here... doing nuthing !
https://www.sau.com.au/forums/topic/29992-exhaust-manifolds/#findComment-610589
Its pretty funny (no offence raist60) when people say I can get xxx kw from this particual part.
Thats the beauty of boost, enough will overcome alot of restriction. Just remeber VL commodores have been running 9s for a long long time - I had a discussion with a guy who owned one, thought the best way to make more power was fully port the head, bigger turbo and up the boost, then was disgusted when he had a very narrow powerband.
Same guy scoffed at the idea of bolting an RB25 head on - there is no doubting alot of power can be made with stock parts, just doesnt mean its the most efficient or 'best' way of doing things.
Just horses for courses I guess.
https://www.sau.com.au/forums/topic/29992-exhaust-manifolds/#findComment-611341
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
