My engine has had some issues and now doesnt have any oil pressure. I havent removed the engine for a few years so am going to have a go at the task in the next few days in my garage.
I have an engine hoist and jack etc, but was interested in what most of you guys found easier (with limited tools), either ripping the engine alone, or taking the gearbox with it. My concern was being able to get the car high enough to get the angle needed to get the engine and box out, or potentially getting the top bellhousing bolts. Wouldnt mind taking the turbo etc out at all the same time without having to do it first.
Engine is an rb30det with 25t box in a cefiro.
Any ideas would be great.
Cheers
Edited by SirRacer
https://www.sau.com.au/forums/topic/299934-quickest-way-to-remove-engine/
Cheers
remove the gearbox first. Last person i know who tried to remove the engine with gearbox attached destroyed the radiator supports.
Im fairly certain i took my 25 out with the box still attached.
But the 31 bay is slightly different, i have a tad more room and crossmember etc sits lower, so that could be a factor.
If i had a car hoist - gearbox would have come out first >_<
took my rb26 out from the top without the gearbox attached no sweat at all
I already had the head off which made it much easier I guess
but with a few (borrow from ya mates) extensions I cant see any of the bellhousing bolts being that bad
am currently wondering though if I can actually put it back in without taking the gearbox out
I seriously doubt it so consider that too
I have a trust sump and long dump/front pipes so that adds to the problem
Been a while since I took one out to and managed by myself without to much sweat
bro arrived just after I got it out gotta love having help eh!
on the floor engine out, leaving the gearbox sitting in the car on a jack or block.. in my opinion its a risky job pulling the engine and gearbox out in one go.. things get damaged and peeps get hurt
guaranteed if you try and pull both out at the same time someone will have to hop in the engine bay to lift the gearbox up to clear the rad support.. if something lets go someone could get hurt real bad..
and the cheap cranes that most companies sell these days come of the floor easily with that amount of weight.
ps. take photo's of as much of the engine bay as you can for future reference!
leave the crossmember and gearbox attached
drop it down onto a trolley jack...
lift the front of the car up with an engine crane or block and tackle, it doesnt have to me super high...
slide the motor and box out on the trolley jack.
Edited by midnight
Pull it out as a unit.
Cefiro's have a nice long engine bay.
Get the front of the car up high and hook the chains back around cylinder 4/5 so you can angle the engine back as you lift it easily and then lift the back of the box easily too.
Edited by badhairdave
I always do my R33 engine and gearbox together. It's all about getting the perfect distance from front lie on location to the hook, and back tie on location to the hook. Get the perfect angle, you don't need to "lift" the gearbox at all.
i pull the motor and box in one unit as well, i dont lift the car at all, except to fit the engine hoist under the suspension arms (only needs to go up about 20mm max) but thats because my car is real low.
As said above, get the angle correct (pretty steep, more than 45 degrees anyway) and its simple, i have tried doing the box seperate and its a pain in the arse to get the box back onto the motor when the motor is getting put back in.
I actually made up a little trolley that sits 10 mm off the floor to sit the rear of the box on when lowering it back in so it slides back without neeeding to sit it on the floor or on a trolley jack which is just too high.
Edited by unique1
how high are you guys lifting your cars that do engine and gearbox in one go?
If you have wheel ramps then that'll do it. Or i just use my axle stands on the highest setting on the front of the chassis rails
remove the engine and gearbox out at the same time. you may need to lift the front of the car up a bit to get it out correctly depending how low the car is.
remember to drain the gearbox oil ;)
no one has mentioned an engine ballancer.
they make the job a lot easier..
i removed the engine and box from my r32 alone with a crane and balancer.
ONE OF THESE
you can use it to adjust the angle of engine and box by up to 45deg either way..
a good way to do it but take my advice... dont to it on your own,,, have atleast 1 mate with you.
Cheers guys, havent done it for a while so will get into it in the next few days. Dropped an auto box and engine out a wee while ago and just thought id let the oil ooze out. Turned into a massive headache so good to remember to do this.
Do you guys remove turbo manifolds etc, or just take the whole thing in one go? Whats the best mounting point you use also?
My stocker came out by removing the dump pipe only off the motor.
My RB25/30 I can't remember if I do it with or with out the turbo... I think I took it off because it sits less then an inch off the strut tower...
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
