yer i found a leak...
The bracket for the heat sheild makes the contact between the dump and turbo realy uneaven...
I have exhaust wrap over the dump. My question is can i go without the heatsheild? does it realy block that much heat? I can just mount the wires up a bit higher near the abs, will they melt or anything?
2. Is the wire/connection that goes in the top of the dump my knock sensor?
do you know a way of mounting the heat shield without using the bracket that goes between the dump and turbo... Cuz it doesnt do up any tighter and there is still a gap cuz its uneven.. I just put it togethor then without the shield and i was just going to put exhaust wrap over the connection and wires that come from the top of the dump... But if it makes a big difference i would like to put the shield back on....I dont know how to mount it tho.... + i polished it last night :D
If I read you correctly, you've stuck the heat shield bracket BETWEEN the turbo and the dump. Right?
It goes OUTSIDE the flange ie dump mounts up to turbo, and bracket sits on dump, then put bolts thru bracket and dump into turbo.
The wire / connection is the O2 sensor.
Nope. The knock sensors are on the inlet side of the block underneath the inlet manifold.
The sensor in the top of your dump pipe is the O2 sensor...
Can't help with the mounting sorry :D
GAWD IM A DUM SH1T!
haha.. i cant beleive i didnt do that..
thanks mate
in the attached image.. the green ones are the bolts that i have done up tight.. the 2 red ones i cant do up cuz there is no room to tighten them cus the spanner or whatever else i use hits the dump and cant be turned... how could i tighten these up? I cant feel any air or hear any leak from it...
ok image didnt upload... I have the four outside ones done.. The other 2 are impossible to get to.
I havent realy tested it out yet.. i have only gone to .4bar.. Should i turn boost down or anything like that first... i only have a bleed running .8 atm... this was before the pipe/cat was put on... Should i be listing to anything while i am testing it?
thanks
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
