Some old guy reversed into me when I was parked, which is a bit disappointing. Anyway does anyone know of any good panel beaters, Iam looking for the best as Iam not paying for it :D
Carrera smash repairs in abbotsford....
but i guess that is a bit too far away from you...ummm
Oxford panels in okleigh these guys do the best job i have ever seen!!!!!!!!!!!
Oxford Panels
44 Oxford St Oakleigh 3166
Phone:9569 9424"
James W.
https://www.sau.com.au/forums/topic/29995-panel-beaters/#findComment-609965
palm motor bodyworks did mine...
did a top job... done a number of other skylines and imports.... but poor old pred had a few issues with them.... not sure exactly what happend tho but it looked mint when they finished
https://www.sau.com.au/forums/topic/29995-panel-beaters/#findComment-610254
same thing happened to me a while ago....mates next door neighbour reversed in to my rear quarter panel while i was parked!!!!!... gggrrrrrrrrrrrrrrrrrrrrrrr!!
anyway since i had nightmares with a panel beater last year that is supppsed to be one of the best around, and is a huge place, but are as professional as a piece of turd, this time i am going to a mates brother in law who has been in the business for years....
i can definately tell you where not to go!!!!!
https://www.sau.com.au/forums/topic/29995-panel-beaters/#findComment-610719
Thanks for the help boys, the damage is not that bad at all considering I will be getting a new bodykit anyway straight after christmas. I will be taking it down to Blackburn Motor Body who are world class and are the authorised repairers for Porshe, Lexus & Mercs.
The guy who hit me was around 90 years old and absolutely had no clue. I rang up his insurance and they basically told me that he had four claims in the last two months, what a joke.
https://www.sau.com.au/forums/topic/29995-panel-beaters/#findComment-611346
What ever you do, don't go to a certain panel beaters on Molan St in Ringwood (there are about 3-4 on Molan St - PM me if you want the name of the one I'm talking about).
I got a $6,000 quote for a repair, then took my car to a trusted (had work done there before) garage and they quoted me $3,500 for it!
There is a good PBeaters... Symes (on Blackburn Rd, cnr Kind St). I bit more expensive (couple of hundred), but they do a GREAT job. Prob, a bit far from Glen Wav. though (~ 30-40 mins)
https://www.sau.com.au/forums/topic/29995-panel-beaters/#findComment-611490
I'm with inark on this one - Palm Motor Body Works. Don't think u can go wrong there really - even if u do have an issue they'll sort it out quickly and in your favour.
It took me two months to get my car fixed.. they're a nice bunch of blokes and did a good job, but if you end up like me, its not worth it - go somewhere else.
https://www.sau.com.au/forums/topic/29995-panel-beaters/#findComment-615342
Admittedly it took palm about 2 months to get mine done too - but they did give me a loan car and every second my car spent there was worth it.
Those guys are flat out there and they take pride in their work. Id rather that than some shitty 2 day job that will look cheap in a year or two.
https://www.sau.com.au/forums/topic/29995-panel-beaters/#findComment-626966
  • 2 months later...
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
    • Cam seals go hard. It's a very old car.
