Some old guy reversed into me when I was parked, which is a bit disappointing. Anyway does anyone know of any good panel beaters, Iam looking for the best as Iam not paying for it :D
Carrera smash repairs in abbotsford....
but i guess that is a bit too far away from you...ummm
Oxford panels in okleigh these guys do the best job i have ever seen!!!!!!!!!!!
Oxford Panels
44 Oxford St Oakleigh 3166
Phone:9569 9424"
James W.
https://www.sau.com.au/forums/topic/29995-panel-beaters/#findComment-609965
palm motor bodyworks did mine...
did a top job... done a number of other skylines and imports.... but poor old pred had a few issues with them.... not sure exactly what happend tho but it looked mint when they finished
https://www.sau.com.au/forums/topic/29995-panel-beaters/#findComment-610254
same thing happened to me a while ago....mates next door neighbour reversed in to my rear quarter panel while i was parked!!!!!... gggrrrrrrrrrrrrrrrrrrrrrrr!!
anyway since i had nightmares with a panel beater last year that is supppsed to be one of the best around, and is a huge place, but are as professional as a piece of turd, this time i am going to a mates brother in law who has been in the business for years....
i can definately tell you where not to go!!!!!
https://www.sau.com.au/forums/topic/29995-panel-beaters/#findComment-610719
Thanks for the help boys, the damage is not that bad at all considering I will be getting a new bodykit anyway straight after christmas. I will be taking it down to Blackburn Motor Body who are world class and are the authorised repairers for Porshe, Lexus & Mercs.
The guy who hit me was around 90 years old and absolutely had no clue. I rang up his insurance and they basically told me that he had four claims in the last two months, what a joke.
https://www.sau.com.au/forums/topic/29995-panel-beaters/#findComment-611346
What ever you do, don't go to a certain panel beaters on Molan St in Ringwood (there are about 3-4 on Molan St - PM me if you want the name of the one I'm talking about).
I got a $6,000 quote for a repair, then took my car to a trusted (had work done there before) garage and they quoted me $3,500 for it!
There is a good PBeaters... Symes (on Blackburn Rd, cnr Kind St). I bit more expensive (couple of hundred), but they do a GREAT job. Prob, a bit far from Glen Wav. though (~ 30-40 mins)
https://www.sau.com.au/forums/topic/29995-panel-beaters/#findComment-611490
I'm with inark on this one - Palm Motor Body Works. Don't think u can go wrong there really - even if u do have an issue they'll sort it out quickly and in your favour.
It took me two months to get my car fixed.. they're a nice bunch of blokes and did a good job, but if you end up like me, its not worth it - go somewhere else.
https://www.sau.com.au/forums/topic/29995-panel-beaters/#findComment-615342
Admittedly it took palm about 2 months to get mine done too - but they did give me a loan car and every second my car spent there was worth it.
Those guys are flat out there and they take pride in their work. Id rather that than some shitty 2 day job that will look cheap in a year or two.
https://www.sau.com.au/forums/topic/29995-panel-beaters/#findComment-626966
  • 2 months later...
    • They need to get a grip. R32 GTRs got as low as AU$8-10K at one point here.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
