Whenever im going high speeds in my 93 r32 GTS, i realised that the HICAS light comes on at the dashboard. Why is this? When i turn the car off and on again the light goes away...
can anybody tell me what that means and how to fix it?
thanks
steering wheel allignment is out . hicas thinks your driving round in a big circle
oh ok but it really wont affect anything mechanically in the car if you continue to drive it, right? Come to think about it, my wheel alignment is way off because im missing a rubber on my left front shock so it veers to the left.
thanks :P
Yeah mine did this last weekend after driving about 150km down the highway... it's never come on before. I've read the other threads about this and aftermarketing steering wheels, I'm not worried about it.
The O.P. has a 32 not a 33.
33's with an aftermarket steering wheel/boss can give problems after about 30 mins of straight highway driving due to poor workmanship in the boss.
32's don't get the HICAS signal from the boss, but down on the pinion shaft on the rack.
I'd try for a wheel alignment first, someone may have altered your steering wheel's central position instead of centralising the tie rod ends.
^ yeh, like i said, im missing the rubber on the front left shock which results in the car veering off to the left...so ill try to get that fixed and get a wheel alighment than we'll see if it still comes on.
PS: I got the stock steering wheel.
how interesting, mine does this at literally random times (I drive a 35km stretch of highway at least twice a week, and it only comes on say once every 2 months), or when I'm going on a long trip say to melbourne. I've never worried about it (and I do have a HICAS lockout), but then I do need a wheel alignment badly.
I dont believe this is true, after pulling off various r32 steering wheels, gts and gtr
the sensor is right there behing the wheel, some boss kits use a plastic plate with 2 slots behind the metal peice, some use a metal peice with 2 slots to go over the sensor to move it
hicas light come on when it detects a fault, code can be read from computer in the boot
if its in the same position for a long time AND you have the limiter removed since the same wire cut is also used for hicas, it throws an error
i dont know about the going in circles thing, does sound plausable
Edited by V-Spec
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
