What do u guys think of this thingy to mount a Gt3076/GT3037 on the stock manifold?
Couple of points to note....
1) No internal WG so no f@&kin around with actuators and dump pipes for proper boost control. :D
2) No excessive heat in the engine room from using a ss high mount as the original heat shield can be reused.
3) No headaches to pull off the ss to repair when they crack
4) No need for a spacer to clear the compressor from touching on the manifold.
5) Everything just bolts up with new gaskets
6) Cheaper
7) Did i mention it was cheaper?
And the cons.....
1) Will it clear the strut tower with added 2.5" or so added to the side?
Does any one have pics with the Gt3076 mounted on the stock ex manifold using either this or the normal flat spacer???
What do u guys think??
Thanks.
is this a cheap chinese no-brander ebay part or is it a proven HKS / Trust / Greddy item?
im guessing a cheap chinese ebay no brander part so its probably not proven / useful
i mean, the exhaust gas is forced out one way and full throttle then a 90deg port is opened
i dont how other gates are setup but im certain they aren't 90deg bends ?
i agree with external gate for better control and stability sure
but if you goto the effort and $ of external gate, you should really do it properly
ghetto external gate setups = not my preference
you get what you pay for basically
Is is a ebay part and i have no evidence what so ever of its results.... kinda why i asked the question in the first place :D
Anyway i had the same concern with the ex gas venting at a 90* angle but i guess its ok since it vents where all the ports has already merged and in a common chamber.
The other ss ones that alot of ppl seem to be using vents from a common chamber also, but at 180*.... ie. in the total opposite direction of the air flow
As i said i have seen no results but it just seem as a very convenient option instead of using a high mount or welding a pipe for the ex gate off the stock manifold.
Its nothing but two T3 flanges connected by a piece of hollow section with a 38mm wastegate flange on one side...... can be fabricated pretty easily if u ask me...... the mechanics of it however is a bit questionable...
And spend the extra dollars on what?????
he is saying (as am i) that its probably a junker product
if you are up to trial fitting and mechanically minded etc then go for it
fit it at home and set it all up and away you go
if the part is ass you remove it and go to how it was
if you arent and you have to pay a workshop to do it then its probably wasted $ as the part could be ass
Do you already have the turbo? if so just pull off the intercoller piping in the engine bay, measure from the face of the flange on the exhaust to the strut tower then measure from the face of the flange on the turbo to the furthest side of the comp cover, add 2.5" and see where you are at, then post it up here coz i would like to know as well.
As for it being a cheap chinese part some are good some are bad, this one looks pretty simple with not a lot that could go wrong, whilst it is better to get name brand stuff sometimes little things like this sometimes have no difference from the name brand stuff.
I also dont believe that the 90o venting will make much of a difference, all a wastegate does it relieve pressure before it gets to the exhaust housing.
Edited by W0rp3D
I went thru the exact same dilemma when I installed the HX35 on my RB30det. and I looked at these but was stopped by the sheer size of the turbo. there was not enough room without the turbo touching the strut tower.
also I was worried about it cracking due to sheer weight.
I ended up using a 20 mm spacer to get the clearance I needed and then going and external gate mounted on the manifold from a section of steam pipe the same as worp3d's but joined at the collector on the top. I ended up with PERFECT boost control and decent clearance. I fabbed up the lot myself and it looks reasonable.
what foolboost has posted is the way to go. but it would require a lot of custom work making it to expensive to justify as by the time you had it done you could have bought yourself a 6boost manifold.
HAVE A LOOK HERE FOR MY TREAD WITH DETAILS AND PHOTOS
Could use one of these :)
post-31991-1260673950_thumb.jpg post-31991-1260673977_thumb.jpg post-31991-1260674000_thumb.jpg
I had to use an adaptor like this to fit a gt35/40r to rb25/30 in r32. The compressor housing was touching the manifold so a spacer was needed and it was a good place to fit wastegate fitting.
If i used a straight spacer, the turbo would hit the chassisrail. as it sits now, i have about 20mm clearance
Yeh i figured the one with the angle will allow for more clearance as seen here
The one i pictured above and all others i have seen that is recommended for the Rb however doesn't seem like it would work without modification.
The holes on both sides are threaded so i guess it was designed to work with studs on either side which will be fine for the turbo side but impossible to bolt to the manifold because even if the thread is drilled out the hole is sooo close to the wall it would not allow for a stud to fit especially where the wastegate flange sits.
Someone on another forum went through this and was left to weld the adapter directly to the manifold
The one "Foolboost" posted however seems like a better option although i think the wastegate flange/type might be a little too big....44mm right?
Anyone know where i can get that type of adaptor???
Thanks.
    • Crazy how good the aero bar looks compared to the stock one
    • Yes, but you will need to rewire all the things that are different. CAS, coils, etc. Yes, but there is no IAT. What? You can use anything you like. It just has to be hooked up so that it will work.     Or are you wanting to just plug and play without having to do any thinking/work?
    • It's been a little over a decade since I bought the S15. As I did on my socials, I'll share some of my favorite pictures from over the years further below. If you haven't realised, pretty much all the pictures in my posts are ones I've taken.  In terms of updates, I don't have pictures, but I acquired a near-perfect pair of fog lights from a friend of mine, so those got swapped in for the pair I already had. As for the JZX110, I just got it back from being fixed. A few weeks back, I was on the highway when I suddenly drove over something with very little time to react. It was probably the size of a soccer ball, but it went under the car and banged into the underside pretty loudly. I pulled over and realized the fluid leaking was fuel, and of course, it was right near my exhaust. This required replacing the fuel tank. If you happen to be in the same predicament, thankfully this car shares a fuel tank with the JZS171, IS200, and IS300, so it wasn't too painful to replace. Enjoy some pictures as mentioned above, including the carnage from the fuel tank and a bonus picture I came across which shows how ridiculously shiny the Bugels are on the 110. So many more pictures I could share of the S15 but this will do for today, enjoy.
    • Welcome.  Was the mistake the car, or joining us? 馃槒
    • Yeap, was me and the daughter getting coffee before heading to the new joint to measure up the fridge space and taking some pics that the solar installer wanted of the switch board
