up for sale is a 4 dr r34 gtt
NEED TO SELL THIS TO COME UP WITH THE MONEY FOR THE HOUSE AS ITS NEAR COMPLETION
68,000kms engine still fresh!! genuine kms
RB25DET
TURBO, MANUAL
ems computer,
600cc injectors,
sard fuelpump,
3inch turbo back exhaust,HKS MUFFLER
HYBRID FRONT mount with custom piping
spitfire coil packs
apexi pen turbo timer
hks elctronic boost control
dyno tune currntly running at 200kws at the rear wheels ( have dyno sheet to prove)
SERVICE JUST DONE, AND DYNO TUNE. ALL DONE BY BOOSTINOZ
HAVE ALL RECIEPTS FOR WORK DONE!!! ALL MODS ADD UP TO OVER 6K
wheels have gutter marks, sprayed painted mat black
few other extras cant remeber,
front bar is abit cracked as picture other then that car runs fine and smooth!! OTHER THEN A FEW COSMETIC STUFF THIS CAR IS MINT
fresh 3 months rego aswell!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PRICE DROP $14.900 NEEED THE CASH!!!!!
https://www.sau.com.au/forums/topic/299979-r34-gtt-sedan-turbo-manual/
This is exactly what I'm after. Just need to save a few more $$. Dang it! :ninja: Good luck with the sale mate. If its still around when I've got enough, I'll definately be giving you a buzz.
Edited by samdasurfinman
This is exactly what I'm after. Just need to save a few more $. Dang it! :D Good luck with the sale mate. If its still around when I've got enough, I'll definately be giving you a buzz.
yeah man this thing is damn cheap dont seeing last around much longer!! bump!!!!! need this gone guys wont find a cheaper 200rwkw sedan with 68,000ks on the clock!!
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
