Okay stole the pic shamelessly from atomik bomber man's build thread
If I am asking in the wrong section sorry
Have now tried three times to install the part pictured below that takes the water feed from the engine side of the thermostat
Brand new fitting from Nissan froze it in the freezer for a day or two
coated in hylomar then installed
checked it the next day still able to turn it with light pressure, DAMN!!!
found I could pull it out by hand now???????????????
Figured hylomar wasnt the right stuff as it doesnt actually dry
So tried Ultra Blue RTV no Good either
black sealant adhesive same same
My main question I see in the pic and thread Daz and ABM have used threebond the Nissan stuff
is this Anerobic ie. will it dry without oxygen present is this why my fitting wont seem to seal???
On another note tried Locktite "Freeze and Release" spray on the old fitting still stuck in my old block
froze up almost instantly and was able to pull it out by hand with little or no effort
May try that old fitting next
sorry for the long post but this f**ker is doing my head in for real
https://www.sau.com.au/forums/topic/300004-rb26-water-pipe-elbow-help-please/
any chance that part differs between engine? could nissan have incorrectly supplied you one from rb20/25/30?
that part should definitely be a tight fit, even without goo
Edited by kristafa
  • 4 weeks later...
  • 3 weeks later...
I wouldnt rely on locktite to hold that fitting in by itself.
Clearly it should be an interference fit into the block.
The continuous expanding and contracting of the block and fitting will eventually weaken the locktite and pop goes your fitting.
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
