I just bought a Bee-r limiter and its not working. I have an r32 gtr with a power fc and tried all the connections that have been suggested to me with no luck.
Has anyone had the same experience or can anyone help me in any way???
https://www.sau.com.au/forums/topic/300010-bee-r-rev-limiternot-working/
There is a wiring diagram, some one has posted it.
But honestly, is it worth killing your motor for?
R32 oil pump drives are fragile at best, if you cannot afford a new motor (and believe me, you WILL kill it)... then don't use one.
thanks boys for your help... i just spent waaaaay too much on my engine to take a risk with this thing....i think it might work if i do a separate earth like one of you suggested but even if it does work there are too many negative things that can happen to my engine to leave it in. so despite how crazy it may sound i might end up taking it out, i'm in a bit of a dilemma. but thanks for the advice, i'll keep you posted.
Here is some info i found which sort of related to Bee-r rev limiter
Spark Cut
Cutting the spark to an engine will stop any chances of a weak mixture occurring, but it carries it's own potential problems due to a large quantity of unburned fuel travelling through the cylinder and out of the exhaust. This petrol can remove some of the oil lining the inside of the cylinder, and pass it thorough the exhaust, again this only becomes a problem if the fuel to one particular cylinder is cut for an extended time. The best way to overcome this is to rotate the order in which the cylinders are cut.
The unburned fuel in the exhaust will have a catastrophic affect if there is a catalytic converter in the exhaust, as it will try to convert the unburned fuel to harmless elements, effectively burning the mixture. This causes the catalytic converter to heat up very rapidly, reaching temperatures in excess of 1000°C, and possibly melting down completely. Thus prolonged spark cut is not recommended for catalytic equipped cars.
ya the bee-r limiter is quite good, id use one over the pfc's one anyday. id rather burn a cat, then leaning out an engine :( imho.
You do know what happens when the unburnt fuel ignites... yes?
The result is what will mince oil pumps... The firing of unburnt fuel.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
