Hey guys, went to an SAUWA Dyno Day today, and the dyno print out showed some interesting results. The A/F ratio dived down below 10:1 and sat on the bottom of the graph for he magority of the run. The owner of the workshop had a look at it and reckons something is seriously wrong with it. Would explain the fuel usage recently. Any ideas what might be causing it? I would take it back to the workshop, but I dont trust them touching my car. No offence to them.
The car is a 1996 R33 GTSt with high flow turbo, full exhaust, intercooler, remapped ECU, stock BOV, Spitfire coil packs, 18psi through a Greddy Profec B Spec II.
Any ideas?
Rhys
https://www.sau.com.au/forums/topic/300039-rb25det-running-crazy-rich/
Hey Ryhs,
I had the same problem where due to the heat today at the dyno (38degree day) my power fc chucked a whole heap of fuel in to stop it pinging and i ended up 60hp less than normal and afrs in the 10's instead of the normal 12's
Hmmm. So you reckon getting it checked on another dyno when its cooler? Like I said before, I'd buy a car and parts off Alistair, but I wouldnt trust him with my car. Possible he's trying to scam money off new customers?
Take it to another workshop to get it dyno'd that you do trust and see if the readings are the same?
Do it on a day without so much heat..
Hey Rhys,
My mate went to the same dyno day and he pulled a low 300 when it normally pulls 400hp
his was tuned by autoworx so i dont think its the dyno reading low, his AFR also dropped down into 10s
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
