>30K SPENT
PAINT TURNS AQUA FROM BLUE SCOOP IS HARLIQUIN !!! CANT SEE IN PICS!!!!!
ALL COMPLIED AND PLATED
WRX MOTOR AWD TURBO ENGINE LOTS WORK
list too big motor pushing 300hp !! SEE PICS!! 3g spent on motor .in the last month (receipts)
INTERNALS
ALL CUSTOM PIPING
BIG INTERCOOLER
NEW GAUGES
NEW BOV
NEW TURBO TIMER
NEW BOOST CONTROLL
FULL WIDEBODY
NEW ALPINE CD WMA MP3
ALL CUSTOM BLACK LEATHER INTERIOR
5 SPEED
18s CHROME
TURBO
FULL DYNO TUNED
TWIN SPORTS EXHAUST TO 2 CANNONS
wicked wrx grumble
PEARL PAINT BLUE TO AQUA
HARLIQUIN SCOOP
ONLY ONE IN WORLD
Edited by katurbo
OK so just let me clarify something cos i'm a bit confused.
Firstly the rear end of the Liberty is an 01ish Liberty, the front end is an 06-08 Liberty, so why have you got Liberty WRX Widebody?
It's clearly an older liberty with a newer front end made wide.
Just wanted to clear it up.
Good luck with the sale mate. Not my cup of tea, but hey each to their own
I think it's '3' cars, as in front body is 2006 Liberty, rear is 2000 liberty and engine is from a WRX.
hope it's all engineered well...
edit: probably won't go well over the pits here in WA :huh:
Edited by mickey
cheers guys,,
ALL MOD PLATED AND LEGAL HAD QLD REGO
yes its a older shape liberty back, 2006 b4 front all widebody. and wrx motor turbo Inside is all black leather.. SOUNDS LIKE 3 WRX'S
$16,000..ONO IS PRICE..
WELL OVER 3OK SPENT. CUT MY LOSSES WANT A STOCK WRX, OR S15 OR RX7 S6
Edited by katurbo
so this is a show car ONLY right ? Im guessing you cant get is registered for road use ?
@ricerice mighty car mods is mad funny :D
@ricerice mighty car mods is mad funny :)
yes can be registered has had qld rego. is mod plated
I saw that on rexnet a while back when it was on ebay. I give credit to the owner who's put the new gen front on it. I quite like that scene, more or so with 180SX's with Silvia S13 Fronts. The thing is that Liberty's are supposed to be the civilized Subaru. Its like Toyota putting a TRD exhaust kit and 18inch Advan wheels on a Camry. Its all up to personal taste. The person is selling he's car, its not a time to tell him off. You might not like the car but you must respect it and the owner.
Edited by Rallye
back on topic...sort of...but what's the car registered as? I mean is the chassis classed as the 2000 liberty? and if so, what was the donor car? GX? GT? B4? etc.
title and subtitle misleading. should say the exact year and model of the car only (doesn't matter if a skyline has a GTR kit if the model is still GTS-T and this car isn't 2006 a liberty). also fails to tell how many kms the engine has done.
cheers guys,,
wrong answer.
B4s were produced in 02-04. Any turbo liberty after that is classified as a GT (unless it's twin turbo) - however all aus spec ones are GT
it may be just because i work for Subaru, but it sh*ts me when ppl call all turbo libertys B4s..they're not!
Quite possibly the worst looking Subaru ever. What have you done to it? You used to drive a honda before.. Didn't you? You've watched too much fast and the furious. The grilles are hideous, the bodykit is disgusting. Your wheels belong on a fobs calais. What do your gauges show? Neon luminosity?
Why ruin a perfectly good car for? Why would you want a stock WRX after what you've done to this one? Go back to Hondas. Seriously.
Watch
. Find out what not to do with a car. Do every Jap performance car owner and get that crushed and never own a car again...
New member and your first posts are trawling another members sale thread?
You are banned.
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
