Just want to know if anyone has done this and how effective it was
I have a problem at the moment where when I run highish boost i can hear the rubber pipe between the AFM and the turbo sucking shut, and the car drops massively in performance. When running normal boost - 1bar, its fine but when I wind it up a bit further to 1.2bar I can hear it really sucking the intake and restricting the inlet air - really frustrating as the little HKS turbo really want to go, but it is being choked!
So I want to change the pipework to metal to stop this from happening, but want to know if anyone has had any troubles, especially with the AFM playing up due to the pipework being changed?
Thanks for any info
Chris
https://www.sau.com.au/forums/topic/30014-afm-to-turbo-pipe-rb20-upgrade/
nah, its been re-programmed so the boost cut is about 22 or 24 psi from memory, definatley pipe sucking shut
When its cold (weather wise) the rubber hose stays quite hard and isn't a problem, I have seen 1.3bar on the gauge in 3rd when it was cold, so its no boost/airflow cut, as they have all been lifted quite high to stop this
This rubber pipe shouldn't close over at those boost levels but installing a nice smooth metal pipe will improve flow. One thing to note is that the original pipe has a section in front of the turbos inlet designed to reduce turbulance in the pipe caused by the turbo. Not having this in place can cause minor airflow meter inaccuracy but will not do any damage.
Interesting, as I am 100% positive that its causing the problem, to what degree I am unsure but high boost is pretty well useless at the moment
What about using some coiled wire to wind inside the pipe? Has anyone tried this?
Yeah this is a sort of common problem. I know (personally) that the RB20 pipe won't support anymore that about 200rwkw, although they can fail at a fair bit less that this. Mine was replaced with a 3 inch mild steel pipe. It works really well, heaps of flow awersome unrestricted flow capabilities. It should definately be upgraded even if you are not having problems with the stock pipe yet.
Ok sounds like it would be best to replace it, as at the moment with 1bar its making 200rwkw, so I am guessing with 1.2bar its just to much vacum for the poor old rubber pipe to handle! Should be a good upgrade either way, I'll keep everyone posted of the results
Can anything be put in the new pipe to replace whatever it is in the standard pipe to reduce the turbulence or is it not worth the hassle....
After reading this i am considering doing the same to my car... 3" mild steel from air-filter to turbo... does it require any other modification....???...
Well if your pipe is getting sucked shut, then it would be very effective to put in a pipe that doesnt get sucked shut.
And as for AFM, no worries, the AFM would be before your pipe starts anyhow :(
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
