OK I've had this weird thought that I should buy a VT/VX SS Commodore GenIII 6 speed. The reasons are I want something that I can tow a boat with next year when I buy one and something a little larger in size so I can seat more people.
I currently own an R33 GTST that I have had NO problems with at all. The only thing is the car will be 10 years old next year and as all cars this old it is showing its age.
Feel free to swing my decision away from the SS but keep in mind I want something NEW not pre 1997. Yes I could buy a 1991 R32 GTR :sly: but these cars are far too old. The engine will be tired and so will be the paint.
So basically I want something around the $25-28k, NEW, powerfull, towing capabilities and reliable.
HELP
https://www.sau.com.au/forums/topic/30016-help-me-i-want-to-buy-a-commodore/
Autech Stagea 260RS - no further discussion required :rolleyes:
fun for the WHOLE family! :)
Maybe not Autech, but possibly a Stagea.
oh and ur looking at figures of about 30% of GenIII's with mechanical problems, major problems.
Where are these statistics from?
10% of people know statistics 50% of statistics are made up on the spot :rolleyes:
Honestly, I don't think a VTii/VX SS is a bad idea.
Guest RedLineGTR
for about $25-28k u can find yourself (well i have seen advertised) a nice R34 Gtt (stock Form) going for about 28-29K the year is a 98 model so its not that old if your worried about it depends what u want to use it for. For that price you have to have a decent look around but these are the prices they are starting to go for.
QUOTE]
Id love an Autech Stagea too, its a pitty that they sell for more than R34 GTRs hey? If only i had a spare 100k lying around.
Im pretty sure there is only 1 Autech Stagea in Australia, the one that was in HPI a while back.
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
