Wakefield + R35 + Willall Tune + Slicks = ?
GGTTRR and I were at Wakefield Park today testing out the new Willall R35 tune, in addition to some Michelin and Dunlop slicks (2nd hand)...
Cars both run a mid pipe, tune, slicks and aftermarket rotors/pads ONLY....
Result:
Marek ran a 1:03.79
I ran a 1:04.00
I can't believe how quick these cars are, it's insane for a car driven to the track (in leather clad and aircon comfort) with essentially minimal mods. I can only fathom what these cars are capable of with some serious setup. You have to remember these cars weigh 1750kg....
Congrats Marek, great driving man.
Edited by LSX-438
https://www.sau.com.au/forums/topic/300165-wakefield-r35-willall-tune-slicks/
  • Replies 67
Result:
Marek ran a 1:03.79
I ran a 1:04.00
Thanks Dunc
Clearly the Dunlop's are 0.21s quicker than the Michelin's
Great driving guys, duncan which pads & rotors, where do you get em and how much.
Dom
I am running Carbotech XP12's with AP Rotors
Marek is running Endless MX72's and AP Rotors.
I've had a quick drive in Mareks car and the MX72's feel better to me. I will not be buying the carbotechs again... I am very impressed with how much the endless pads look after Mareks discs too - they still look like new after two track days.
Forgot to mention that mine is a tarmac rally and occassional track use only vehicle. IE not used on the road.
would that nake a difference?
I really dont know anything about the demands of tarmac rallies (they scare the bejesus out of me btw!!) so i couldnt say, sorry mate. There are a few people on here who can help though, i am sure.
Result:
Marek ran a 1:03.79
I ran a 1:04.00
Unbelievable times guys. Well done! Where are you sourcing your 2nd hand slicks from?
Awesome work guys, thats motoring in anyones book! Great to see Marek out there and kicking some serious butt too.....looks like a two way fight for the title next year if ever I have seen one :)
That's the plan Martin, I don't want Duncan to have it all to himself :P
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
