Wakefield + R35 + Willall Tune + Slicks = ?
I source the slicks from a guy who has contacts from the GT and porsche cup boys.
I caught
of an interesting tire setup i've not seen before on an R35.
You get a good look at the wheels/tires from about 3:00.
These seem different, yet again, from the latest Super Taikyu GT-R's wheel/tire setup.
Can't find any info on the net though.
  • Replies 67
I caught
Thanks for the video, very interesting. Advan slicks hey... they look pretty much the same size that Martin, Marek and myself are running (18's too?). The car seemed a bit unstable under brakes? Maybe is was pushing really hard. Running aftermarket brakes and coilovers too.
Guys,
Just to put these times in perspective....check this out:
http://wakefieldpark.com.au/index.php?opti...2&Itemid=49
The lap records at Wakefield.....the GTR is up there with Porsche cup lap records and would have smashed the improved production record that currently stands by over 2 seconds.
Well done again guys on the times.
  • 2 months later...
Guys,
Not to mention they'd put the frighteners into some of the bike boys.
What tyre size are you running with the 18's mate ?
Edited by The Law
tyres which seem to work are michelin 27/68/18's (all four corners).
weight reduction was Willall racing titanium exhaust and susequent power increase from same
next time out i will be running less pax seat (another -30kg), race wing and splitter (martin?)
Sounds NICE !!
With those quoted tyre sizes are they imperial measures ??
Guys,
Haha, but to put that into perspective... these $160k+ cars with $x000's worth of mods only beat a Toyota starlet (on road tyres) by less than 4 seconds... ;)
But seriously, damn impressive times. I wish my car only took that long to get down the front straight.
No, they are metric sizes.
27 = 27cm = 270 mm tread width
68 = 68 cm = 680 mm overall diameter
18 = 18" wheel, OK this one is imperial
Thats a fair bit lless rolling diameter/overall diameter than standard tyres, do you notice the car is lower/guards dont look filled out ?
Edited by The Law
Very impressed with the times!
To put throw a few other cars times up- a dude off ausrotary did a 1.01 in his FD RX7 track car on 19 inh slicks, t04z- but as I said- full track car.
The Unique Autosports 300zx has done a 1.04.65- http://www.advanwheels.com.au/cars/unique-300zx.aspx
Hey, can you post a link to the Natsoft results. Curious to see the times the MR2 you overtook at the 1min mark.
that was a practice day, no official times. Last time out with natsoft timing at wakefield (on re55's) i ran a 1:05.3 i think, so the slicks seem to be good for a second or so around there. We'll be going out again in the next few days to improve on these times i hope. Does anyone think we could manage a 1:02?
Edited by LSX-438
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
