Wakefield + R35 + Willall Tune + Slicks = ?
although this is getting off topic, I found my sprint track lap at QR the other week was a full 0.8 seconds faster (58.2 versus 59.0) recorded via the Video Vbox lite versus the transponder thingy on the windscreen they plaster on.
I was hoping you would of said .91 seconds. Im chasing a 56 @ qr in the R32 GTR! :thumbsup:
  • Replies 67
although this is getting off topic, I found my sprint track lap at QR the other week was a full 0.8 seconds faster (58.2 versus 59.0) recorded via the Video Vbox lite versus the transponder thingy on the windscreen they plaster on. The unit quotes sampling at 10 Hz and of course as above, using algorithms to factor in velocity etc to improve accuracy. Any more thinking about it than that however makes my head hurt so I will concentrate on driving better. I hope the errors in each unit though are all relative and not random. reliable incremental gains are what we are all after, not just outright times.
back to the topic at hand
You've convinced me Dunc - 18 inch wheels & slicks, Cobb tune and maybe,just maybe an R2.two are all coming soon.
I was at Sandown with my VBOX3i and recorded 1:27.72 V's the NATSOFT 1:27.72.
Each time I have tested a Performance Box/Drift Box or VBOX mini V's my equipment (VBOX3 or VBOX3i) and used at same event where there was the "official" time it was the same.
i spoke to my mate over the weekend - he actually pulled high 1:07s with his R32 (which was my old aust delivered gtr) with mild tune on factory ecu, pads and shagged slicks...this was with 2 people in the car
not bad for a 20yr old car.
the r35 though is definitely in its element on a larger track as its not the smallest or lightest car out there
  • 5 months later...
a postscript to our development with the mighty R35, we have now achieved a 1:00.8x at Wakefield. Incremental mods since we began are E85, coilovers and new slicks. With more setup and experience i reckon we would ultimately see 59.x's - and this is with a road rego car driven to and from the track (slicks swapped in and out of course).
Edited by LSX-438
i thought 1.07s in a stock r32gtr was quick...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
