Hi Guys,
I need some help please; I have a '96 R33 GTST. I was stopped by the cops and they checked the vehicle inside out to find some defect. But since I have everything stock, they could not find anything. They have then reported to the EPA that the vehicle is too noisy. I got a letter from EPA to get the car checked for noise level. When they checked it, the noise level was within spec, but they failed it saying it has a non standard Cat converter. I then took it to an exhaust place and they replaced the cat converter with a Magnaflow 91006 and said that it should be fine for the test. I paid $ 350.00 for this. When I took the car back for testing they said it's still not the standard cat converter and I need to do an emissions test at RTA. I did this test but the NOX value is slightly higher than what they want. I have two options now, Get a standard cat converter fitted (I don't know where to get one). Get the car tuned to pass the emissions test, this is going to cost me $1000.00. Would appreciate any help you guys could offer.
Thanks
https://www.sau.com.au/forums/topic/300178-standard-catalytic-converter/
It'll help if you tell us where you are, so that more guys might sell or loan you one in your locality.
Checked 'F/S' thread?
Put yourself in the 'Wanted To Buy' thread?
Welcome to SAU too!
Will that fit the R33?
should unless u got a 2.5" or sumtin lol... im not sure if u can bolt it straight onto the 33 pipes either... so i guess u may have 2 cut n weld or bolt the cat onto the stock pipes
Aren't catalytic converters a consumable item, ie they wear out? If you find a 15 year old cat will it give the right value to pass emissions?
I'd do some research before buying someone's dodgy cat :)
+1, I would use your new cat and get a tune, Unigroup Engineering comes to mind, just tell them it needs to pass emissions.
ive got a spare standard cat in my garage, as long as your exhaust is a direct swap jobbie it will bolt straight on. im in bankstown. pm me if you're interested.
Sorry mate, I cannot PM yet as my post count is less than 10. My mobile No is 0414933343 please txt me yr details and I will buy it off you.
Thanks
yay another hills R33.
Use the new cat and get the car tuned, i'd be surprised if any r33 gtst's would pass an emissions test stock standard without a tune anyway.
And thats crap about not having the standard cat, Cas is right, they are a consumable and you will never find a brand new Nissan replacement for an r33 (unless s15 silvias are the same?) EPA are idiots.
Good luck
i had a look at the cat he had in there just then, it was a magnaflow one that looked exactly same as the standard r33 one except it had a better looking (and better flowing i'd imagine) core.
either way, the standard cat i put in there should get him out of trouble.
Ur a good guy.
Polizia/EPA R gettin picky - too picky
Ur a good guy.
Hi Guys,
Getting picky? They are idiots! I got the standard cat from Security installed. The guy in Granville who does the EPA check, rejected it again (cost me $60.00 each time). I asked him what he wants, and he goes I need the original cat from Nissan not anything else. I told him Nissan Australia has no stock of R33 Cats, he says it's not his problem; I need to find an original cat or pass the emissions test. I called around a few places that do compliance and found a place in homebush that has got an original cat. Will get that fitted and see what he says (another sixty bucks for him). I have to get it passed by the 24th. If I drive the car without passing after that, the fine is $11000.00. There is no R33 in NSW with the original Cat, because they have to change it for compliance. Warning guys don’t get caught with a Smokey or noisy car, or the idiots are going to get you.
Sounds to me he's just being an ass & wants to force you to pay the $1k for the "magic" tune.
When my mum went to NSW due to work, she brought her old POS 1/2 dead VN commodore with her & that thing passed the pits on 1st go & it had a non-function CAT.
Sorry to hear about this. :cheers:
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
