I'm changing all my brake rotors and pads this weekend so I thought i'd clean up the calipers and maybe repaint em.
So far im going with a metalic red color, really just w/e red i can find.
But I'd like some ideas on colors that would go well with my car, so far im going with a silver/black scheme (body kit wont be on for another 2-3 weeks (HTFU! :( ))
Also what prep work garantees a good job and what paint should I use.
pic of the car:
https://www.sau.com.au/forums/topic/300183-caliper-paint-job/
Hey mate, I recently repainted my calipers blood red or orange/red as it's known. Go to Repco and they will show you this colour, it's not the usual boring red, it's metalic and a tad orange - makes the car look really hot.
Ok how to get best results...here's what you gotta do...
1. Take your rims of one by one (if you only have a standard car jack) - alot of people spray with rims on - this is a no no as you cannot get to the hard-to-reach corners and it won't be a complete job...so you take your rims off and sand it down as much as you can so that there are no rough surfaces or left over bulky paint bits left...spend at least 20 mins sanding each caliper down...
2. Buy some good quality primer (the grey primer) - spray one at least and no more than two coats of primer onto the caliper allowing 35 minutes for each to dry then repeat.
3. After the primer has completely dried and has setted. Apply two coats of the colour paint, spray like 2cm away from caliper with an up and down motion moving from left to right evenly. Make sure to cover/mask off unwanted areas before painting. Allow each coat 1 hour to follow dry then repeat second layer. In my opinion, two layers is plenty as more will just make the caliper look bulky and over-painted.
4. Put your rims back on but do not drive or move the vehicle at all for 24 hours. Spend some time going through over-spray areas with a cloth and some strong detergent like petrol or paint removing liquids.
5. Get a soft piece of cloth or tissue, put some wax onto it and then wipe over calipers once. This is to remove any dirt or dust gathered to bring out the sign...then drive your car off...it's done!
I strongly suggest this blood red colour but other options which also look nice include: gold, black and dark yellow. Each to their own...Gold and black would probably be nice and subtle whereas red or yellow would be loud and 'in your face.' Depends on the look you want to project.
Good luck.
Kevin
I'd recommend at least removing the caliper and unbolting the brake line holder from the base, so you can rest caliper on the ground or on the lower control arm...then you've got a bit more mobility for sanding and painting..
Taking the calipers off altogether and dismantling them is the way to go though...then you could anodize them ?
But yeah, definitely not a fan of these dodgey paint jobs while the caliper is still fixed to the knuckle assembly....stupid half assed idea if you ask me.
  • 1 month later...
Im going to paint my calipers in the next few weeks and I am looking for a nice red colour. Spunky Munky, you mentioned about this blood red or orange/red caliper paint from Repco. Last week I drove down to my local Repco store and asked them for this colour. They had no idea whatsoever. Do you know the brand or anything that can help me show them what I am after – perhaps a picture of the paint can? Would you happen to have a picture of your result? Sounds like a nice colour.
Edited by S1LV3RTRACKS
tbh i spent ages trying to find the right paint, ended up buying 4 different cans lol!
repco/autobarn/super cheap, are usless when it comes to getting the right color.
I ended up using a firehydrant looking red on the front calipers and disks looks rly good, but im looking for a metalic red as I think it would suit my car more.
but none of the above stores stock any cans of metalic red caliper paint :(
looks like i will be paying $100 or so to get a litre of paint made for me.
but none of the above stores stock any cans of metalic red caliper paint :D
try and find a can of duplicolour metal cast, they have an anodized red that looks pretty wicked
you'll have to ring around to try and find it though, i found some at my local supercheap
I really like the look of the duplicolour metal cast anodized red. Found some at my local Supercheap at $20 a can. Need what they call duplicolour groundcoat also, so assuming one can of each will do four calipers the price comes to $40. Going to attempt painting in a few weeks when I have some free time. Was looking at the Anodize your brake calipers thread - some good information with pictures in there.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
