Beautiful little charade, white in colour, 4 door, no rust or damage, few marks around the body but nothing major, only had 2 owners its whole life well looked after rego. till next yr, low k'z, nothing to spend everything works, starts first go every time, and does 550kms to $35 worth of petrol.
located in Sydney
price: $1100 ono.
PM if interested
https://www.sau.com.au/forums/topic/300191-daihatsu-charade/
located in Sydney
price: $1100 ono.
PM if interested
any pics and wen does the rego expaire?
  • 3 weeks later...
    • He is around but doesn’t really do automotive stuff anymore, mainly does commercial work now
    • Shortly after I do the usual full exhaust/ fmic/fuel pump/ R33 turbo and still get flogged at the lights by i30Ns
    • Is Chris from Craved Coatings still around? He is an ex SAU guy and did great powder coating (back in the day at least)
    • Bumping this thread yet again, has anyone ever tried putting yet another vacuum regulating valve on the hose that goes between the turbo inlet? Something local owners have mentioned is the Radium breather pipes de-restrict the valve cover but it actually produces an undesirable outcome in practice, way too much air is sucked out of the crankcase and a ton of oil comes with it as well. As far as I can tell the PCV diaphragm in these modern euro wet sump performance engines is active during boost as well, there's just a check valve to block boost from entering the valve cover and crankcase as there's no inherent check valve function in these diaphragm-type valves. Hopefully I'll be able to try some of this out soon. The Volvo XC90 4.4 V8 has a nice external version of these things.
    • So when will the Samsonas, twin scroll turbo setup on go?
