VIP / drift kitted style Toyota Chaser, fresh import from Japan at Sep 2009(doc provided)
2500cc VVTi Turbo tunned with 240 klws on wheel
perfect air/fuel tuning more potential
Extra Spec:
Factory Xenon h/lights (beam level adjustable)
18" BBS racing wheel
2ways LSD diff
FULL HKS Turbo back exhaust system
hks intercooler kit (with piping)
tannabe alloy raditor
hks injector
after market fuel pump.
trd strub brace
project mu's brake pads and rotor
orc clutch
HKS EVC IV Boost Controller
HKS Adjustable Suspension
biltz Intake system
alpine CD/MD player
Remote control Alarm
original JDM VIP/DRIFT style body kit with factory paint.
paint is in perfect condition. no extra need to spend.
will swap for a GTR R32 / R33 GTR with similar value
CASH SALES PRICE $19500 / SWAP CAR WILL BE $22000
car is already register with VIC rego
it come with 1 year rego currently
this is one of the best chaser around in states.
inspect is a must
interest call 0438222228 allen
https://www.sau.com.au/forums/topic/300215-jzx-100-~~chasers/
hi guys thanks for the comment.
johnbarry88 : interstate transport can be organise with extra (no hard at all)
SS8_Gohan: car was in garage since last week end may be you see a different one.
car still for sale
cheers....bump~~~
why, fairly straight forward to move cars around interstate
was this car at the RE night just gone?
that was mine... silver series 2 with the same wheels and the same kit hahaha
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
