VIP / drift kitted style Toyota Chaser, fresh import from Japan at Sep 2009(doc provided)
2500cc VVTi Turbo tunned with 240 klws on wheel
perfect air/fuel tuning more potential
Extra Spec:
Factory Xenon h/lights (beam level adjustable)
18" BBS racing wheel
2ways LSD diff
FULL HKS Turbo back exhaust system
hks intercooler kit (with piping)
tannabe alloy raditor
hks injector
after market fuel pump.
trd strub brace
project mu's brake pads and rotor
orc clutch
HKS EVC IV Boost Controller
HKS Adjustable Suspension
biltz Intake system
alpine CD/MD player
Remote control Alarm
original JDM VIP/DRIFT style body kit with factory paint.
paint is in perfect condition. no extra need to spend.
will swap for a GTR R32 / R33 GTR with similar value
CASH SALES PRICE $19500 / SWAP CAR WILL BE $22000
car is already register with VIC rego
it come with 1 year rego currently
this is one of the best chaser around in states.
inspect is a must
interest call 0438222228 allen
https://www.sau.com.au/forums/topic/300215-jzx-100-~~chasers/
hi guys thanks for the comment.
johnbarry88 : interstate transport can be organise with extra (no hard at all)
SS8_Gohan: car was in garage since last week end may be you see a different one.
car still for sale
cheers....bump~~~
why, fairly straight forward to move cars around interstate
was this car at the RE night just gone?
that was mine... silver series 2 with the same wheels and the same kit hahaha
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
