2010 F1 Season
Roy
 Share
  • Replies 3.6k
Posted Images
This probably should have happened years ago, not that his dad has done a bad job (that I can tell) but F1 is several orders of magnitude bigger than anything else.
Is there any particular reason for ragging on Martin Brundle? Has he done a bad job previously? Bear in mind that his record as a driver has nothing to do with his skills (or lack of) as a manager.
I don't particularly care who manages a driver, unless they have a conflict of interest in managing a team as well (are you listening Flavio? Of course not). Hakkinen, though ... I'm not sure. I think he could do better. I don't recall him being noted for his media skills, one of the key skills for a manager (liaising with the media). The 2MB guys are much better at that (are they still together?).
Having Brundle commentate and manage a driver is like Eddie Macquire calling Collingwood games, there is already an established bias, whether intended or not... I'm not saying Brundle is a bad manager, in fact I bet he would be rather good, but to do so whilst he is commentating does tarnish his ability to be totally partial..
Perhaps, although bear in mind Brundle's role in the telecast, he's there as the technical expert and ex-driver, so he's there more to fill in the gaps from the other guy (I forget his name) than to give his opinion. At least that's the theory. I do agree, though, that when it comes to the media, you shouldn't play both sides of the street.
haha campos is now HRT F1.... wonder if the supporters will be a pack of bogans
HRT also stands for Hormone Replacement Therapy ... wouldn't want to be a woman working for that team. Or a girly man.
Will the bigger fuel tanks/loads be to the advantage of the larger drivers?
Could be, the driver weight difference will be a smaller percentage of the overall car weight so will affect the car's performance less. I don't think it makes a lot of difference anyway, they all bring the cars up to the minimum weight with ballast anyway. The only difference is the lighter drivers have more options re: placement of ballast.
 Share
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
    • People just don't understand how good MX5's actually are and how fun they are to drive, park, manuever. You feel like you have got some fun cheat code, while everyone else is sitting in their luxobargeSUV like normies who missed the point of living. It really is that noticable. As long as you/your stuff fit, and you're comfortable (they are), a MX5 is the best car on earth to daily around.
