  • Replies 3.6k
Posted Images
cracka puh-leez; it's not like Ferrari are in any way a shining example of sainthood
do you really wanna have that argument? apparently when some underling inside McLaren does something wrong, the FIA holds Ron Dennis personally accountable (obviously it'll be Whitmarsh now), yet when the TEAM PRINCIPAL of Renault orders one of his seat-warmers to have a stack, Renault is in no way responsible for that :D
and it's got nothing at all to do with the fact that a Renault withdrawl would have left F1 with no dual manufacturer|engine supplier team bar Ferrari (until the recent advent of Merc GP, of course)
p.s the shortcut idea is some dumb-ass shit
Maybe you missed the :) in my post.....
The KERS system provided us with some overtaking last year. So why don't they introduce a "push to pass" system. Doesn't have to work like KERS with batteries and energy recycling etc., but how about a giving each car a few extra RPM for 1 use per lap or something?
You don't see any drafting anymore and you don't see anyone overtake down these really long straight aways either. Something's wrong with F1 and they need to fix it.
I'm so close to ignoring F1 and playing GT4/5 on PS3 instead!
I think the short term solution is to make it 2 mandatory pit stops. At least then we won't see everyone just surviving to make it to the finish line on their worn out tyres.
It really was a joke watching the front runners turn to survival mode and try to make it to the chequred flag. If it wasn't for Vettel slowing and a few cars catching and passing, there would have been no action whatsoever!
Dear God, no. What is this, Mario Kart? Collect enough coins and you get a turbo boost? Why not design the cars so that they can pass each other the old-fashioned way, you know, by out-ballsing each other?
Two problems. One, the brakes are so good they're only on them for a couple of seconds, even for the biggest stops, which doesn't allow for out-braking. The difference between braking too early and overshooting the corner is only a couple of tenths. So we need to downgrade the brakes. Don't whinge about it being a safety issue, the cars and tracks are safe enough that reducing braking performance by 25% or so won't significantly increase the danger.
The other problem is the aero. As a previous poster stated, they can't draft anymore and most of this is because of the complex aero. The FIA is trying to modify the cars to overcome this but it hasn't worked. I can think of a few things that might help:
  1. Ban diffusers. They seem to cause a lot of the turbulence.
  2. Reduce the HEIGHT (i.e. thickness) of the wings. To see what I mean look at the rear wings in Monza-spec. You can't read the sponsor's logos from front on because the wing elements are much flatter relative to the ground.
  3. Look at re-introducing ground-effect as a way of maintaining corner speed, although this may not help
  4. Bring back the POWER! Reduced straight-line speed means reduced drag, which means less drafting. Get the cars back to 900 bhp or so.
Anyway, that's my two (billion) cents. For me the golden era of F1 was the 80s, safety issues aside there was some great racing. Get the cars back to near that spec, while maintaining safety, and the racing will improve.
+1, there's no real point in having 900+ hp if you aint got the traction to take advantage of it.
They have plenty of traction to cope with the power, and anyway, even if they didn't, having to battle wheel-spin and oversteer is going to lead to more passing.
Well I was think it's alot better idea than Bernie's solution of introducing short cuts. I've seen the push to pass button work well in other open wheel series so why not?
I don't think it turns F1 into Mario Kart at all. There are no such coins to collect! The money has all been spent! lol!
I think we can all agree that something needs to change in order not to suffer more boring GP's.
Just about anything is better than the short-cut idea. Honestly you wonder what the guy puts in his brownies sometimes. Like the idea of having medals instead of points ... :D
My point is by simplifying the engineering you can make the racing better and cheaper. The trick is to do it in such a way as to keep F1 at the pinnacle of motorsport ... you can't have F1 cars being outpaced by Indycars or something.
should def look at making changes that enable chasing cars to follow their prey very close at racing speeds without any of these tedious downforce/overheating issues. road cars have more sophisticated aerodynamic aids than F1 cars are allowed to have these days- having a variable aperture for the radiator inlets could probably compensate for the hotter air when drafting. they should at least be allowed to have something like that, and make it an automated function linked to water temperature.
the return to steel brake rotors as mentioned would probably help a bit too
all you have to do is throw in a right-hand turn and the Indycar is f**ked! :D
Can we expect the Australian GP to be any better? I don't think Albert Park lends itself to overtaking any more than the Bahrain circuit, in fact, probably less.
What's the easiest solution to implement? Make the compound difference between the option and prime tyres greater? Enforce 2 madatory pit stops?
I have a feeling nothing will be changed in the short term. We are all going to have to suffer watching boring processional GP's or watch/follow something else.
Did anyone see the season review of the European Carrera Cup on OneHD yesterday? For a one make series, there was plenty of action and overtaking. Blew F1 out of the water for entertainment!
It would be good to see them make some basic changes to the track, honestly, there is a couple of things there that could vastly improve the racing at Albert Park, atm it is a little 'stop - start - stop - start', sorta like Montreal without the massive back straight... :(
The easiest fix is make the drivers neck a 6 pack before qualifying, then before the race go to King street for a big night out, necking beers and banging dirty crumpet. Come the race it will be great to see the real men able to punt a car quickly with the load of a excessive night on the piss on their mind
Hahaha! That's what good ol James Hunt used to do! It was good enough for F1 drivers back then wasn't it?
James Hunt - What a legend :(
whincup and button to swap rides for a blast around the track tomorrow
should be able to hear it from work... so close now, cant wait
I'll be heading over there shortly, hopefully I can get access to the gate.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
