2010 F1 Season
If the current relationship is between the diff and the speedo, then no, you will not need a speed sensor in that hole in the gearbox. If the car were an R33 GTST, or an R34 GT-T, then it would need a speed sensor in there. Because that's what those cars have/need. If the car were an R32, then it will need a cable drive cobbled together from a Navara speedo drive, because R32s can't handle an electronic speed signal to the speedo.
Just to follow up on this. Will the speedo work with this? Like to have plugged speed sensor on this trans and still using one on diff from N/A (open) diff?
The opposite experiment is equally viable. 10L of petrol in the tank + 2L of metho.
I think you'll find that all fuel in some countries has 10% ethanol in it.
