2010 F1 Season
Roy
 Share
  • Replies 3.6k
Posted Images
Well the two Macs and Webber are within 2.5 seconds of one another and the cameras are not following it.
Hopefully Button starts thinking about a move in 10 or so laps and we see some racing in the middle of the top 10...otherwise, dud GP!
EJ gold.
Alonso apparently lost sight of what Massa was doing off the start......
well he was jammed against the pitwall by Vettel so I guess this was technically true. :(
EJ is such a flog.
Alonso made the "mistake" at the start?
didn't realize getting jammed up against a wall and still making the pass was a "mistake"
EJ needs to head to Italy and count his money!
Bugger off you Loon!!!!
Not sure about Webbz RBR eating its oil........
Maybe he is running an N1 pump and no sump baffles?
Big End Bearing on the cards????
 Share
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
