The only guy that hasnt been making mistakes this year is Button. He has been good, but the slowest of the 5. Take away his opportunistic wins in the wet and he would have been nowhere. It leaves Webz as about the most consistant, which if you consider Aus GP, Valencia and some of his backards on the first lap shows that all the real contenders have been as bad as Hamo and Massa were in 2008!
  • Replies 3.6k
Posted Images
I KNOW, LOVING LIFE ATM
QUALI MIDDAY 2MORO ON 1HD
this is already more interseting than Monza!!
Quali tomorrow kind of changes my sunday, but thats almost a full day of F1, bathurst, more F1 and then motogp... sweet action
Oops !
5 place grid drop for Hammo !
http://news.bbc.co.uk/sport1/hi/motorsport...one/9076871.stm
I suppose you could call his off remotely Senna`esque.
Alonso for the win.
Veettool to bin it.
Webbo.
the Kub, then button.
Wild card being Shui if it rains.
Looking forward to quali when I get in from the pub.
cheers cokey
Hamilton will be on a mission as he has absolutely nothing to lose now...but he will be back with Kamikaze Kobayashi at a home race. Can't waits for that...
I can't agree with Schuey having any hope of beating his team mate unless Rosberg bins it. Wet or dry.
Kubes to beat Alonso into 3rd.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
