every sports betting agency now has RBR at $1.02 to take the constructors title. yay
and aren't i going to be back-pedalling like a mofo if Aussie Mark does actually clinch the drivers title...
It will be interesting to see how Ferrari fare for the last 3 races.
They are using their last engine and still have 3 races to go ....
i prognosticate we'll be seeing some scarlet cars towing voluminous clouds of bluish-white smoke along before we get through this season
  • Replies 3.6k
Posted Images
So really MW must win at Korea to have a comfortable chance. Unfortunatly I can see vetool taking out the WDC and Webz retiring.
Wow. That's an impressive level of negativity. The RBRs have in fact shown extremely good reliability and Mark has proven he has the smarts to race hard without breaking his car. Yes, I know there was Valencia, but his rivals have also tripped over themselves. The difference is that Mark has been more consistent.
Mark is 14 points in front of Vetool and Alonso. What this means is that if Mark can finish second in two races, one of his rivals must win two races and score one point more than Mark in another. If Mark can win even one of the final three, he will almost have to DNF in one of the others to lose, as this will give him a 21 point lead, no matter where his rivals finish. To put it another way, if Mark wins in Korea, or either of the other two, he only needs two third places to win.
I can cut it all sorts of ways, but the truth is Mark Webber is in a very strong position. If he finishes on the podium in all three races, he will be nearly unbeatable.
Of course, a DNF changes everything, but for once Mark seems to have luck on his side.
Yeah, putting in a faster lap than Vetool ... how dare he. All must bow before the Almighty Blonde One!
I dont know how anyone in their right mind can go for Vettel, i feel like breaking his f**king finger everytime he gets somewhere he starts pointing it saying im number one. Yeh number one in dummy spits you freckle faced German flamin mongrel.
When are people gonna wake up, Vettel is not a good driver.
How can you say he is not a good driver? He has won 7-8 GPs! Dont let the fact that you dont like the guy cloud your judgement. I think at this point of their careers Mark is showing he is the more complete driver...but who knows if that will be enough for him to win this years WDC?!?!?!?!
Agreed.
Much as I loathe the little prick, I have to admit he has some talent. Give him a couple of years to develop some maturity and he might make a top notch driver.
Even over the last few races he seems to be settling down a bit, or maybe people have learnt to steer clear of him on the track.
    • So left off with high hopes of having a gearbox in pretty quickly........ Got the adapter plate that week and had to chase a few threads and work out how/where everything goes as no instructions. Got the adapter fitted, test fitted gearbox and found had to cut and shave a few things. Tunnel required some hits with a decent hammer to give some clearance on passenger side but it fits with no problems,  could fit a 8hp70 with a little more work. For a cross member I wasn't going to spend $1100 on so shiny machined piece. Went through a few designs and remembered I had a gktech s chassis to cd00# cross member. Fitted that and found its close enough with a few extra bits welded so have gone that way and still a work in progress.  After this got into modifying the intercooler with some bends and clamps. I was procrastinating on this as was not keen to cut up and weld it myself but happy with the outcome.  Onto the radiator shroud and oil cooler mount. This thing took way longer than I thought it would but having to add an extra oil cooler for the trans and wanting everything within the chassis rails its good enough for now. It mounts to the chassis and gives plenty of room for lines and pipes. All the coolers are rubber mounted and sealed the shroud on the top and sides, will use some tape to seal the bottom gap of about 10mm. 20250508_111500.mp4   Next job was to build the new diff and after a delay with a friend got built this week. I ended up putting it all together with supervision and was good to learn how to set one up correctly. I ended up going a 3.69 ratio, nismo 1.5 way gt pro with gtr Axel's. Stripped it all down, gave all the parts a good clean, pressed on new bearings and set backlash. Was good working in a clean assembly room with all the gear. Once got home wire wheeled the case and hit it with some rollbar/chassis black paint. Got a few more bits done but will leave them for the next update.
    • That could be drilled, ground and welded. Would stop it progressing and leaking. But that block shouldn't be pushed very hard, as what you see there is a massive warning sign. But that fix also isn't going to happen properly with the engine in the car, and assembled. So you're looking at anew block if you're doing all that work anyway.
    • It's not as simple as it is being made out to be. It s not hard, but there are things that have to be done. Am busy right now, but will try to essay later.
    • Pinout is different to my knowledge, but you should confirm to be sure. Also you will need to adjust the VQ table in Nistune to suit. I would still recommend sticking with recirculating BOVs, I'm not sure if the R35 card MAF will fully resolve stalling caused by reversion/throttle lift.
    • What issues are those? Previous owner said it wants to stall sometimes. We did test drive and it was nice and smooth so it will be sporadic or idk. And if i just change MAF(the sensor to R35 version) it should be better? And as i asked...is it like "plug n play" with oem MAF from R34?  This is a MAF from R35 right?
