Problem With Fuel And Tempurature Gauge
hi all
I recently bought a 04 white v35, found problem with fuel gauge. I filled up the tank the needle only display 3/4 full and fuel light alway on. the tempurature guage / needle does not move at all. took the car dealer as still until warranty. they used a scanner and says fuel system and temperature is running normal. it just doesnt display correctly and need calibration.
it is schdule to be fixed in jan next month
is it big problem? any one have similar problem? how can this happen?
apart from these, the car runs fine and speedo is correcy
I hope these are small problem and hope to resolve asap so i can enjoy the ride.
hi all
Hi Mate,
I have just bought a new 04 white V35 coupe and I am also facing the exact same problem. Fillled up the whole tank and needle only went to 3/4 full. My needle moves but tends to be quite inaccurate. My light is fine though. Did you happen to get this fixed?
Thanks.
I had the same problem with my 92 Maxima. I'd like to blame it on a dirty resistive track on the fuel sender in the tank but with all the fuel sloshing around, that should keep it clean. I ended up fixing mine myself by painting a thin film of conductive carbon ink on the worn pads but this stuff isn't cheap to come by (about $200 a bottle) but I use it for a number of other applications in my line of work so that was my justification for it.
I'm not sure if you can just get that as a replacement part. I do remember asking around for my own reference including my favourite Nissan dealership but I can't remember if I had to get the whole assembly (minus the pump) or not.
Edited by The Max
Where did you guys get your car from?
My fuel gauge is the same. I fill up and only 35 litres can go in and the gauge fluctuates from full to three quarters full so at half full the gauge shows empty and the empty light comes on. Any clues????
It is usually the fuel sensor, know fault check the US g35 sites for more detail.
With the needle on the temp you can do some checking yourself. get the servicing manual and they have a sequence you need to do with the ignition and the pedals to enter into diagnostic modes to test the dash. This will tell you if there is an actual problem with the needles or the dash.
Edited by ther
it is scheduled to be fixed by a electrician in january. will let you guys know how it goes.
the dealer says it is electronic problems. he used a scanner to check tempuratue and fuel and said it was correct.
I hope it is only electronics problem
  • 3 months later...
Ok I can Confirm now that cleaning the Fuel Sensor with Q-tip is working. First my fuel gauge only shown 3/4 full when filled up to the max. Now it's all fix now.
pw350gt, do you think i can get a mechanic to do this for me. I am not confidence doing this Diy. how long did it took you"?
I think your Mechanic should take that long to do it for you. It took me an hour because i spilled the Fuel onto the Rubber O-ring and it expanded. TOOK me heck a long time and frustration to put it back. As long there isn't a problem with O-ring, i don't think it'll take that long at all probably 30 Min.
I Suggest leave the Fuel at about 1/4 full to be on safe side. If you are not confident just show your Mechanic the steps how to do it.
Good luck
 Share
    • I joined this group years ago when I got my hands on an R33 GTS-T and was excited to get some mods on it. Unfortunately, I had to do the adult thing and sell it to buy a house. Fast-forward six years later, and I have been blessed to be in a position to buy an R33 GTR next year.   I am getting close to buying my dream car, I would like to get the community's advice on modifications. I have researched mods in the past but I feel newer and better things have come out since then (2018).    Goals: I would like to have a 400-500hp daily driver. I would also like to get the engine dressed up (Wire tucks, rocker cover pain etc etc). I would also like to use it for track days but more for fun rather than competitions.   I am moving to Brisbane, Australia so any good mod garage recommendations in the area would be appreciated.
    • Thanks everyone for the replies/suggestions on my issue here. I'm still trying to diagnose the root cause of this. Things I have done so far: A week ago, I disconnected my 12v constant relay mod and returned it to the stock FPCM wiring: I could hear the sound of the fuel priming was different because of the FPCM limiting the amount of volts going to the fuel pump. From memory I think it also primed to 43psi. It was very hard to start it. I don't think from memory I could start it at all. I had to then ground the fuel pump to the chassie and then it could start after a couple of cranks. Fuel pressure did drop a bit to about 45psi (i think). It was idling even worse than before. 🤔 It was also doing the same weird RPM tacho thing. So I've returned it back to the constant 12v relay mod for now as I investigate more. Right now, I'm in the process of deleting my aftermarket immobilizer, an old Japanese turbo timer, and another aftermarket transponder immobilizer that the previous owners put in years ago (from sexspec days).  Just curious to see if this whole bird nest would cause some weird electrical problems. The Viper 5900 immobilizer stopped working a few years ago, and I pulled out the main fuse on it years ago to stop it from being a parasitic battery drain and I haven't bothered to clean up the mess there, so now is a good time to. There was a RPM signal wire that spliced into the RPM tacho signal from the ECU harness. I've taken it out. I've already pulled out the Viper immobilizer and returned all the joints wires/splices back to factory. I let the car idle and it's still the same idle and RPM tacho idle issue. Now I'm going to delete the turbo timer and the other key transponder immobilizer (autowatch) and return splicing/wiring back to factory setup. Just to see if this might be causing some electrical issues. It might not, but I just want to get rid of it anyway. True!, I was actually thinking this the other day. I will check with another new vac line to make sure this is not the issue.   This is actually on my to-do list, and you might be right, this might be a shit batch of fuel because I filled the tank up to 3/4 full from near empty, then I went to the shops and it happened straight after that. I've always filled up from this servo for years with no problems, but yeah might be my first batch ever batch of shit fuel from them. Will be doing this next when I get my hands on a container/jerry can. I just didn't think to do this straight away because it doesn't really explain why the tacho RPM thing is happening. Maybe I'll chuck some injector cleaner in the new batch too?
    • The videos on Youtube look terrible, they don't seem to do much to a fire at all. I wanted to replace the extinguisher in my car with something smaller but I might hang off this move until there's good evidence.
    • I'm a frustrated audiophile. My "listening room" is also the big TV/movie room. So the stereo speakers are also the front pair for the surround. They are Ascension Summoners, by Adelaide Speakers. The guy who runs Adelaide Speakers designed and built for a couple of the renowned speaker manufacturers that were based in SA back in the day. The centre channel ends up looking a lot like yours. It's the same driver setup as this type But I got him to put them into a sideways oriented cab the same size as the side/rears I got. The fronts are flat down to ~20Hz, so I don't have a sub. This is all driven by a very high end Pioneer receiver - so nice but nothing special. And worse, because the fronts can draw so much power at high volume levels, the bloody amp goes into self protection and shuts down if you turn it up too high. 8 ohm nominal can easily mean 6 and modern consumer oriented amplifiers are not as well reinforced on the supply side as they could be. I keep meaning to do something about it, but somewhat like my earlier obsession with DSLRs and Lenvy, I actively resisted dropping more money in there until the urge decreased. If I keep listening to music at really high volume levels I'll just cut more notches in my hearing anyway. They one at 6kHz is bad enough - I need to behave myself now.
    • After a few weeks with the new layout, I'm thinking.... Change "Engines & Forced Induction" to "Brooom brooom pssht!" Change "Suspension, braking, tyres and drivetrain" to "Rattle rattle, shriek, crunch". Will be better.
