For anyone with a GTR still running the stock twin turbo pipe that's interested - I got a mate to weld a divider into mine, just got it back today and it turned out pretty good....
If you don't know what the mod is all about, it's been fairly heavily discussed over on the UK GTR site, you can check it out here - http://www.gtr.co.uk/forum/84482-testing-m...turbo-pipe.html
They actually sell them from the shop on the UK site, but the shipping is pretty steep and you have to send them back your stock pipe.
Anyways, if anyone wants their pipe done just let me know and i'll give you my mate's workshop details.
Don't know if he's the cheapest around, but I do know he's a perfectionist and the welds are sweet and the cut for the dividing plate is in exactly the right place, apparently took him about 2 1/2 hours.
https://www.sau.com.au/forums/topic/300281-gtr-twin-turbo-pipe-divider/
Interesting mod...
I have some issues though with the thread.
1. No idea how they work out 10whp gains, that borders on the impossible to measure.
2. The graphs are done "by eye", so point 1 even more relevant. Easy to see where 10whp comes from, its all guesswork.
3. But then he didnt "race a flow bench", so why is he racing dynos? :cool:
4. Then they go on to compare 2.8ltr strokers results vs 2.6... on what i can only assume is eye plotted graphs again.
Silly thread in terms of actual testing. It's all "seat of the pants". Conjecture in my books.
They also talk a lot about surging in that thread, so it would seem tuners over there don't know what tuners over here do...
Not many people have surge issues in strokers & GT-RS in Aus. No-one has any issue with surge on -5's either. So whatever they are doing over there is causing their surge problems if over here nobody has any drama's.
Let us know what you think/find after swapping it out though. Im skeptical to say the least at this stage.
Yeah, I laughed at some of the science in that thread too, but linked it in more to explain why they are doing the mod.
Just looking at the way the flow from the turbos comes together at almost 90 degrees in the stock pipe compared to how it looks with the divider, it isn't hard to imagine some gain though, even if only a relatively small one.
I don't know if i'll bother putting it on now though, as I am about to put in a new set of turbos, injectors etc along with a retune, and will probably just swap the pipe over at the same time.
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
