Am after the V35 auto ratio of 3.3, which is different to all the R33 and R32 ratios
Your other options are to see if a 3.3:1 FD ratio is availabe aftermarket.
Otherwise, find a manual diff and see if someone with a slusho FM platform car wants to do a swap of the ratio. The speedo reads off the rear ABS sensor on our cars so changing the FD does not put the speedo out, and in the US its quite popular with auto owners to do a 3.5:1 (or even a 3.7:1) FD ratio swap.
Thanks for the comments, scathing.
Understand diff ratio will not affect speedo accuracy.
There is a 2006 manual Z33 diff on ebay for $250, would have bought it if it were right. The US guys quote $500 for the parts for a ratio change. Then I would have to get someone to do it (I can install the diff). Probably $1000+
Am looking at buying a low km 2005 Z33 auto diff from a wrecker, which will give me lsd (stop VDC going off all the time), just it is expensive, $800+.
Is that diff on eBay the entire pumpkin as an enclosed unit, or is it just the internals?
If its the former, you could see if someone with a slusho Z wants to just do a direct swap. Maybe offer them a VLSD fluid flush on the 3.5 FD you're giving them to sweeten the deal, which shouldn't cost a great deal extra. They drop their diff off their car and you fit it to yours, and call it quits. You wouldn't need to open anything up, which would bring down costs as you don't need new washers and seals and shit.
You could even offer to do the install for them, if they're happy to trust you with it, so it'd cost them absolutely nothing for a 3.5:1 VLSD conversion on their car.
Thanks, Nigel
Sounds very good. Send me a PM.
Thanks for the comments scathing, just thought there was too much risk mucking around with the diff on ebay. Someone else bought it in the end (mmm maybe I alerted them to it). Didn't want to get stuck with another part I don't really need. Anybody after a 6 speed box? haha
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
    • That's odd, it works fine here. Try loading it on a different device or browser? It's Jack Phillips JDM, a Skyline wrecker in Victoria. Not the cheapest, but I have found them helpful to find obscure parts in AU. https://jpjdm.com/shop/index.php
    • Yeah. I second all of the above. The only way to see that sort of voltage is if something is generating it as a side effect of being f**ked up. The other thing you could do would be to put a load onto that 30V terminal, something like a brakelamp globe. See if it pulls the voltage away comepletely or if some or all of it stays there while loaded. Will give you something of an idea about how much danger it could cause.
    • I would say, you've got one hell of an underlying issue there. You're saying, coils were fully unplugged, and the fuse to that circuit was unplugged, and you measured 30v? Either something is giving you some WILD EMI, and that's an induced voltage, OR something is managing to backfeed, AND that something has problems. It could be something like the ECU if it takes power from there, and also gets power from another source IF there's an internal issue in the ECU. The way to check would be pull that fuse, unplug the coils, and then probe the ECU pins. However it could be something else doing it. Additionally, if it is something wired in, and that something is pulsing, IE a PWM circuit and it's an inductive load and doesnt have proper flyback protection, that would also do it. A possibility would be if you have something like a PWM fuel pump, it might be giving flyback voltages (dangerous to stuff!). I'd put the circuit back into its "broken" state, confirm the weird voltage is back, and then one by one unplug devices until that voltage disappears. That's a quick way to find an associated device. Otherwise I'd need to look at the wiring diagrams, and then understand any electrical mods done.   But you really should not be seeing the above issue, and really, it's indicating something is failing, and possibly why the fuse blew to begin with.
