Hi, I bought my 1997 r33 gts-25t about a week ago and it didn't have an alarm. After going around to various places to get quotes for one, when I was cleaning my car the other day I noticed a strange box underneath the dash. After googling the 4 letters that were actually in english on it I found out that it's an alarm system, however I didn't get the remote with it. I was just wondering if it's usual for importers not to give you the remote? Also is it possible for an alarm shop to install another brand remote to work with this system?
Thanks
Matt
https://www.sau.com.au/forums/topic/300337-r33-alarm/
usally the dealer wont even see the remote to the alarm, they will just get a key to the car and thats it, wethere its from the remote being lost on transport or just not being sold with the car, as for another brand remote programed to it, it all depends on the alarm its self, maybe you should post up what letters you found on the alarm and anything else you know about the alarm system, i know chris rogers knows alot about different brands of alarms and remotes, as for me im know knowegable on alarm remotes and what alarms they will work with, just how to knstall them. one of you better options in the end might just be to have a professional install a new alarm and remove the old one.
https://www.sau.com.au/forums/topic/300337-r33-alarm/#findComment-4990905
could well be the dealer fitted nissan/alpine thing I remove. is there a security light on the dash that is marked 'seciruty'?
easier to rip the lot and put a proper one in. (properly!)
https://www.sau.com.au/forums/topic/300337-r33-alarm/#findComment-4991204
Thanks for the replies, I was thinking that getting a new one installed would be the best way, just thought that I might be able to save some money by just getting a remote coded to it. The current alarm is http://blog.livedoor.jp/joy_carlife/archives/64868838.html. I just used googled translator to translate it. Does anyone know approximately how much it would cost to get a mongoose M80 installed?
https://www.sau.com.au/forums/topic/300337-r33-alarm/#findComment-4991375
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
