Howdy all, so as some of you know I sold my R34 last October which was a hard move for me but it had to go.
I ordered my new car - a daily driver 6 months ago and it's final here! Talk about a long wait! Anyhow it was 100% worth it, it's fantastic. It's a MY10 Audi A4 with a bunch of options, a few are sports suspension, sports seat and wheel, 19" RS4 alloys and Xenon upgrade with LED tail lights. Anyhow now I have a car I actually like driving again I'll be sure to head out to some events. I'll have to dig out some SAU stickers for it!
Oh and one funny thing I notice, there is a huge number of SAU'ers that have moved from Jap to Euro. I can think of me, Ferni, Mav, Lewah, Nathan, Snowy (well he still owns a R35) and I'm sure there are more out there. Bit of a trend huh! Maybe a Euro cruise in in order :)
https://www.sau.com.au/forums/topic/300346-my-new-car/
  • Replies 46
Yeah I am looking to sell one of mine, what are you looking to do with it?
drive it?
GTR replica with an L28(when the money permits)
wouldnt mind a sedan.. but would love a coupe
also gona keep the stock engine and other bits so if i wana go back to original i can
https://www.sau.com.au/forums/topic/300346-my-new-car/#findComment-4989844
[quote
Could be the older we get the more money we make and the more conservative we become.
https://www.sau.com.au/forums/topic/300346-my-new-car/#findComment-4989932
Sorry what I was asking is what are you looking for. A shell to rebuild or a complete car. I have both but only looking to sell the compete shell. It of course comes with all the bits to go with it.
probably a good condition shell with little to no rust. but again. i wont have the funds till febuary.
and thats when both the hiluxes are sold and the garage emptied.
is there enough parts to build her up and use her as a daily"?
https://www.sau.com.au/forums/topic/300346-my-new-car/#findComment-4990014
Little to no rust and C110 don't belong in the same sentence sorry :)
Your dreams of finding a car with little rust may be shattered pretty quick. I'm going to put the car up for sale early next year so keep an eye out :D
good.. must be cheaper then :woot:
i got a mate who can weld and i have a sheet metal cutter and bender..
pm me what your looking at and how bad the rust is
and how rude of me! congrats on the aooowwwdiiieeee.. their fkn nice cars (y)
Edited by GTR-boy
https://www.sau.com.au/forums/topic/300346-my-new-car/#findComment-4990090
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
