Hi People.
My question is, does the diameter or width of the hose which goes from the boost controller (manual) to turbo make a difference?
I have been changing some factory hoses with silicon hoses, and for this particular hose... when i took it out and looked at the inner size of the hose (the hole) it didn't exactly match up with the sizes of the silicon hoses I had.
I tried putting a smaller size (this was very tight, and I took it off just incase it would split at where I had managed to connect it) and I tried a size that was slightly larger.
When i pressed the accelerator, the boost guage seemed to react the same for the thinner or wider hose.From this I assumed it didn't really matter.
When I started the engine though...it sounded a bit different. It didn't seem to be as loud. When I took it for a drive....(well it's kinda hard to describe) but the boost guage was behaving the same (if not going up higher) but the car seemed to lag slightly?
SO BASICALLY, Does the inner diammeter/width of the hoses going in or out of the boost controller make a difference? I assume it would, as it's controlling the air pressure right? So a wider hose would have the same amount of air at less pressure?
Bare in mind I have next to zero knowledge about turbos. Thanks in advance for any help.
yeah there is probably a reason why all good boost controllers come with different sized lines . 6 mm for boost sorce and to solenoid and 4 mm for boost reference signal
Once the line is under pressure there is no difference. It's the difference in time it takes to pressurize that line that is important. The difference in time it takes is the amount of volume between the two sources that air has to occupy. (Think of a bigger example as intercooler piping and the turbo needing to pressurize all the piping before it gets to the intake).
For a boost controller this can mean a spike if it takes to long for the line to pressurize and then the boost controller to bleed off the air it needs. We are talking fractions of a second in such a small line. So if a line is really long or really large in diameter, it can make a difference and cause a spike that would not have occured if the line was shorter or smaller. With the diameter of most vacuum lines used for boost controllers, you aren't talking much. For example going from a 4mm hose to a 6mm hose would be the equivalent volume as say another extra 5cm in line of the 4mm hose (For example. If you want to do the calcs for the exact amount of a given length you can)
So in other words unless you are using 1/2" vacuum line for your boost controller it aint going to change sweet f**k all.
Keep your lines short is the main thing, dont have them looping half way around the engine bay and then into the car through the dash if you want your boost controller to work well.
Edited by PM-R33
It can make a difference. Length indeed makes a difference as well. I've seen it first hand.
Length and diameter over say 2-3 meters (seen people hide bleeders on drivers side of the engine bay) etc etc.
Being the hose gets hotter and expands more and more the larger base you start from.
Well... that's my guess anyway :)
depends on how thick the walls are. the thicker, the better it will perform in terms of being prone to kinking and closing up on itself in vacuum. ive seen plenty of the thin walled hoses close up on themselves.
size matters boys :)
Hmmm, you know what...I reckon I'll put up a pic of the 2 hoses side-by-side....then i'll let you decide.
SECURITY...that's a scary a** display pic you have man...wouldnt wanna meet him in a dark alley.
Lukas33....mmm that's a sexy a** display pic you have man....they wouldn't wanna meet me in a dark alley.
haha sorry mate. had to.
as long as theyre short they should be no problem.
HAHAHA YES!!! i was going to point that out but thought I should keep my serious hat on. Then you went and did it :) Top work :laugh:
Yeh well after your line busting like that Phil Im surprised you didn't recommend it, Must admit though it does make you engine bay look the sex.
Yeh I have a Profec B Spec II aswell and its about 20cm from cooler pipe to solenoid. So its very short. So as long as its long enough to fit in the gap but not too long as it doesn't get pressurised/hard quick enough AND as long as it is thick enough. It should hold any load/boost without spiking nicely
pussy, shoulda kept stuck into it! :ninja:
HAHAHA Stock internal 25 on 2.5 bar......harden up phil.
He is not joking about everything being braid either. He has braided electrical wiring going to the ceiling light. He has even made a steering wheel cover out of braid. Rumor has it that he has redone all the plumbing in his house with braid.
Hmm looks like I have to change it back or get another one anyway.
It started making a high pitched whitsling noise today. And I'm guessing that's either because of a hole in it, or crack, or the plastic ties aren't tight enough but yeh....some sort of leak.
Oh well, back to the drawing board.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
