Hello all,
My 90 R32 GTST has recently finished getting an RB25 swap. During the swap it was decided that we remove HICAS and use the RB25 power steering pump (from a C34 if that matters).
Unfortunately my steering is quite stiff, not to the point where I would say not working, just not working properly, the wheel does not return freely. What could cause the heavy steering?
What is the motor or sensor that is connected to the steering rack? Cause its not connected at the moment (what does it do?)
The Hicas ecu is still plugged in, however I snipped the green wire on the smaller plug to turn off the dash light.
Is there some sort of steering speed sensor that needs to be connected? where is it located? (could possibly be connected still just throwing out ideas)
I also have an aftermarket hub and wheel put on at the same time as the swap, Im pretty sure the hub was for an R32 with hicas but i cant be sure... the turn signals do go off when i turn straight though.
thanks!
Edited by Delux_247
Well we plugged in the solenoid on the rack and made sure the wires were conductive and still pretty heavy.
So, I have been reading that if the HICAS ecu reads something wrong it will go into limp mode right? well I all the lines and anything related to HICAS except the HICAS ECU and rack solenoid have been removed. Will it always be in limp mode?
Do people that have HICAS removed just have to live with the heavier steering? (Ive learned the heavier steering is because the car always thinks is traveling fast and so it stiffens up the feel?)
The steering angle sensor thing could be out of alignment but this will usually take a couple of minutes of driving before it throws an error.
Did you put a 25 box in aswell? is the speedo working correctly?
Do you get light steering for a couple of minutes or is it heavy from the get go?
the feel of the steering never changes, never is light then gets heavy. Just always heavy.
i have an rb20 transmission and the speedo works fine
at the same time I installed a r32 boss hub and nardi wheel, it turns off the signals just the same as the oem wheel did(the oem wheel didnt turn off the turn signals all the time but the steering felt fine)
is the steering assist thing on the rack controlled by the HICAS ECU? where can i find a wiring diagram for a gtst?
Same problem as i had
Was a headache working it out
You can run 5v directly to the steering rack
I can find out which resistors we used
that would be amazing if you could!
I wouldnt mind the steering if it was a track only car, but being a daily driver its a pain.
could also be using rb25 pump on a steering rack not built for it each series of pumps put out different flow rates perhaps look into changing the rack over
Ive also briefly thought of this.
we've noticed that the return line is large, and thought maybe changing it to a smaller size would increase the pressure and help out. Of course too much pressure and we would blow the seals...
another thought was to do the s14 rack conversion
Edited by Delux_247
There is a brass restrictor in the supply line to the pump perhaps removing that could increase flow?? but as you said could be to much pressure and blow seals ?
If you do the s14 conversion you should be able to get rid of the hicas computer i think meaning if speedo cable breaks it won't affect the steering making heavier you have to check what controls the pressure on the s14 rack example on a track day doing 140km/ph you don't want super light steering it needs to ramp up slowly that could all be controlled by the s14 pump not sure haven't seen one .
Im doing this conversion right now, and have encountered the need for the rb25 pump as the balancer has 3 ribs for power steering and the rb20 pump is 4 ribbed...
Would love to know how to keep the steering the way it was, could you use a 3 rib belt and the rb20 pump?
Or has anyone solved this one?
I recently removed the hicas system on my r32 and decided to use the smaller pump off a rb25 but they have the different ribs, I then got the rb25 pump removed the shaft( its shorter ) got the r32 pump removed the shaft ( long shaft ) pressed off the pulleys swapped the 4 rib pulley to the short shaft re-installed removed half the body off the r32 pump use the back cover off the rb25 bolt it back together needed to grind the back plate to refit into r32 backet and not a problem steering is the way it was before
im doing this at the moment.. but im using an s14 rack and pump to do away with all the hicas shit, it also has a nicer plastic resovoir, looks a bit neater :/... the rack doesnt have the solenoid and is 1kg lighter, there is only the one pressure sensor in the line... apparantly the s14 rack has less turns lock to lock but i wont know till its all done.. the s14 pump has a seperate pulley (not attached to the shaft) so i can change it with a nice aluminium one, either 3 or 4 rib, depending on what the balancer has.. im also mounting it down low, where the a/c used to be...
i will be making a build up thread now that im getting things done and my brain is starting to kick over.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
