hey all. Was hoping someone could provide any information on what the hell my diff is doing.
R33 GTR - non V-spec
Redline Heavyweight shockproof oil.
Rear diff, when one rear wheel gets slightly airborne, it spins, but under power in carparks, it skids...
what the??!!
I just wanna put power to the ground!
Nigel.
https://www.sau.com.au/forums/topic/300433-rear-lsd-not-acting-like-it-should/
Hi Nigel. From your post its hard to understand what the issue is, but it might just be the way you explained it. I recently put lightweight shock proof in my stock gtr diff and had issues. Basically when i was trying to corner or park the car, the rear of the car would shudder and the diff would feel like and open one. It felt like the oil wouldn't let the diff bind up. i put motul back in, and the problem cleared up instantly. Maybe drop the redline oil and try something else and see if it solves your problem.
I thought shudder = tight diff, not loose one. I was told that shockproof will give you more shudder, but that's because it increases the friction between the plates like a tighter diff would have. Makes sense in that many use it to compensate for loose synchos as well.
Not supposed to use Shockproof in LSDs, it doesn't have the LSD additive.. I've heard of GTR LSDs locking up in low speed situations like around roundabouts with shockproof in them, I run Redline 75w90 gearoil in my rear factory LSD and don't have the issues you speak of.
+1. Wrong oil can make the diff shudder/tighter...
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
