What options are there for steering wheels in R32s that are legal? My fiance is very short.. and I am quite tall and with the stock steering wheel in a position that is comfortable for her to drive, I can't physically get into the car ^_^. The simplest solution that doesn't involve moving the steering wheel up and down constantly is to simply get a smaller diameter one. However I am led to believe that any steering wheel with exposed metal that is less than a certain diameter is not roadworthy and can be defected. Thoughts?
https://www.sau.com.au/forums/topic/300457-legal-steering-wheel-options/
or buy her her own skyline :D
Actually I think Dave is talking about his fiance's Skyline not his.
Dave, I'm not sure if you have thought of getting quick release wheel or deep corn style?
I think smallest you can get legally is 330mm (according to Vicroads RW requirments).
Actually, best option for you to overcome this is to drive your GTS4 instead of driving hers :huh:
Cheers
Yeah im looking at getting a new wheel too, the stock one i have is really worn and wont pass scruitineering at hillclimbs. but i dont want to have one for driving and one for events as that'll put me off if they are a different diameter. A mate of mine just bout a frigging expensive MOMO wheel from japan, bare metal inside, for his S13, i wonder if he knows its not legal...
So 330mm and a padded centre. Thanks guys. Ya this is my fiance's car not mine :D. Quick release is a possibility I will consider.
The car is staying strictly legal as it gets driven a lot and she's a worry wart about such things too :).
My bro (in his s13) got pulled over for random checks, his old steering wheel has bare metal in middle. All the cop said was "buff out the shiny metal part as it was too reflective" and admired his transformer badge on the horn button. He also bought a 2nd hand momo wit bare metal in middle again, but haven't been pulled over as yet.
No R32's were fitted with an airbag
In that case, I'm fairly sure that a non-airbag steering wheel would not be legal, but I can't remember where it says that in the law....so I'll let someone else check if they want to confirm. See the EPA/road worthy sticky there are links to the Vicroads rules there.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
