What options are there for steering wheels in R32s that are legal? My fiance is very short.. and I am quite tall and with the stock steering wheel in a position that is comfortable for her to drive, I can't physically get into the car ^_^. The simplest solution that doesn't involve moving the steering wheel up and down constantly is to simply get a smaller diameter one. However I am led to believe that any steering wheel with exposed metal that is less than a certain diameter is not roadworthy and can be defected. Thoughts?
https://www.sau.com.au/forums/topic/300457-legal-steering-wheel-options/
or buy her her own skyline :D
Actually I think Dave is talking about his fiance's Skyline not his.
Dave, I'm not sure if you have thought of getting quick release wheel or deep corn style?
I think smallest you can get legally is 330mm (according to Vicroads RW requirments).
Actually, best option for you to overcome this is to drive your GTS4 instead of driving hers :huh:
Cheers
Yeah im looking at getting a new wheel too, the stock one i have is really worn and wont pass scruitineering at hillclimbs. but i dont want to have one for driving and one for events as that'll put me off if they are a different diameter. A mate of mine just bout a frigging expensive MOMO wheel from japan, bare metal inside, for his S13, i wonder if he knows its not legal...
So 330mm and a padded centre. Thanks guys. Ya this is my fiance's car not mine :D. Quick release is a possibility I will consider.
The car is staying strictly legal as it gets driven a lot and she's a worry wart about such things too :).
My bro (in his s13) got pulled over for random checks, his old steering wheel has bare metal in middle. All the cop said was "buff out the shiny metal part as it was too reflective" and admired his transformer badge on the horn button. He also bought a 2nd hand momo wit bare metal in middle again, but haven't been pulled over as yet.
No R32's were fitted with an airbag
In that case, I'm fairly sure that a non-airbag steering wheel would not be legal, but I can't remember where it says that in the law....so I'll let someone else check if they want to confirm. See the EPA/road worthy sticky there are links to the Vicroads rules there.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
