Hey guys.
Just a quick question regarding the disposal of the various fluids that are removed from our vehicles.
i.e engine oil? Where abouts can you take it? Dont really want to be dodgy here. :ninja:
Coolant Fluid? Sure its mostly water, im thinking of just tipping down drain. But want to clarrify before i do it.
Power steering?
Brake Fluid? (guessing both these would go with the engine oil?)
Cheers. Luke
Hey Luke,
Good to see others being environmentally aware :huh:
I take my oil to WSN Environmental Solutions at Seven Hills (Sydney NSW) they don't charge you if its less then 20 litres.
www.wsn.com.au or Phone 1300 651 116.
Cheers
Johno
I have been meaning to ask that same question and I have about 4 or 5 bottles of used oil just sitting in the shed. That WSN place looks good does anyone know of something like that in Melbourne?
your local Council should have an oil and vehicle waste scheme available
i put all oil and coolant back in to containers (2L coke bottles are gun) and take them to the council tip on selected days - along with batteries and tyres.
not gonna like this answer but its better than "down the drain"
i just put all my used fluids in 5L oil/coolant bottles then leave it at the door of local mechanic overnight
Its not perfect. But yes. Certainly better then tipping it down the storm water.
Thanks for the comments guys. What about coolant?? Am i right to tip the water/coolant mix down the drain? or is that a nono?
NO NO. The active ingredient is ethylene glycol, plus various anti-corrosion chemicals - not really designed to be sent through the stormwater or sewage systems.
Take them all to your local council's recycling station - I know the Monash one on FTG Rd near Blackburn Rd will accept them. They might charge a few $$, but what price saving the environment?
every race track I've been to has oil/coolant recycling, and so does my local tip. no charge.
that or just pour it into a car you car about less. for me that is the navara
If its just oil form your oil change, i just pour the stuff on weeds around my garden, kills em good, also i pour it on outdoor wood, like garden edging and stuff, stops it from drying out, and around fence bases stops grass growing there and keeps dogs away...may sound crazy but it works...
and technically its recycling
Edited by doozooby
Ye if you guys are in melbourne there is a couple I just found. There is a transfer station in wantirna charges 50 cents per litre which isnt to bad.
LOL at leaving it at your local mechanic, I was actually thinking of doing that one time. Glad I'm not alone haha. But I think I will just go to this transfer station.
Just keep in mind that yopu cannot mix your old oil with petrol/degreaser/brake fluid/coolant.
Each one has to be kept seperate, they are poured into different recycle bins. I think brake fluid stuffs old oil actually.
Frankston "Waste & Recycling Centre" aka the Tip will accept engine oil for no charge.
Dunno about coolant.
That's kinda the opposite of what you should be doing :D
putting it on fenceposts etc isn't bad. it prolongs the life of the timber, meaning less is needed to be cut down, and less bought timber treating products are required, so less refining, etc. and it isnlt like it is washing into waterways, etc. it is probably less harmfull using it to kill weeds and to put around the base of fence posts than half of the herbicides that are on the market.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
