Radiator Fan Blade Problem
Can anyone assist me??
I have a 1989 Skyline, 6 Cyl., 3.0Litre, S/Wagon that requires a replacement fan clutch and fan blade, however I seem to have stumbled upon a problem where the two do not fit together? Let me explain:
I purchased a genuine Nissan Fan blade from Nissan (Pt. No. 21060-55S01), and then after reeling in disbelief at what Nissan wished me to pay for an original Fan Clutch ($400+), I went to my local parts agent and purchased a aftermarket unit.
All was going well until I attempted to join the two together, for I found that the mounting holes on the fan were too far apart to fit onto the fan clutch. I measured them and found them to be 143mm apart, whereas the holes on the fan clutch were 133mm.
I contacted the Manufacturer of the fan clutch, who assures me that there were two fan blades, and that their dimensions are 133mm and 136mm. When I explained the problem he assured me I had the correct one, and that in fact the fan blade I had was for the model engine (2.6Ltr./6Cyl) after mine, which uses a fan blade of 143mm between centres.
I contacted the Nissan dealer that I purchased the part from and He assures me that I have the correct part, and even faxed me over a copy of his parts list which shows only one part number for my engine!
I realise that things happen, but now I am confused as to what I should do, and I would welcome any assistance more experienced people can provide. Please excuse any out of place comments, I am new to "forums" and such.
Thank you, Bob
Edited by Bigbob
i have come across this with RB30 & rb25 clutch assy being different, but both are available aftermarket. $110
Thank you, Bob
Dear BezerkR32,
Thanks for the response, and special thanks to the others who have responded it is really appreciated.
I got am email from the Manufacturer of the Fan Clutch, who states the following:
"It is also possible Nissan have superseded all there parts to the later model that does still take the same water-pump.
I know it's a hassle but you may need to pull off the clutch first and match it up by measurement."
He is again reinforcing the statement that the Fan Clutch is correct and that Nissan have changed in some way.
Thankfully he has given me another Fan Clutch Number, which has the same C to C measurements of the
Nissan Fan Blade.
Because my vehicle is a Nissan I would like to use Nissan parts where possible, so I am thinking that I should
remove the current unit on my vehicle, measure it and then compare it (Both blade & Fan Clutch) and see what
comes of it. (My engine ID Plate says: RB30 175778A, Build date April 12 1989)
What do you guys think? I am trying to keep my vehicle as Nissan as possible, but this is becoming a challenge
that requires a strategy. I do appologise for not replying to all your messages, I am not really good at these
Regards, Bob
UPDATE: As of 22/12/09.
The "other" cat number that fitted my radiator fan, was nearly as expensive as the original Nissan brand. (seems it is imported from Japan) so even though it did and would have done the job, it was far too expensive this close to Christmas, so I optioned for a VL replacement part.
I returned the Fan blade to Nissan, which they (thankfully) accepted with no issue. I then went to a Wrecking yard and bought a VL fan-blade, then went to my Auto parts dealer (who had originally told me to use a VL unit ) and he was able to exchange mine for the correct unit.
I installed it today without too much difficulty, and all seems to be working OK, now. It seems that my intentions although earnest were not to be, and thanks to those of you on this forum I'm able to get on with keeping my Skyline in good condition, my thanks to all thos who helped me, and if anyone comes across this problem I would only be to happy tho provide any information that may be of assistance.
PS...... Merry Christmas ( I got mine present today :) )
 Share
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on.
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
