Here's what I did over Christmas
I bought a 40mm triple core radiator from Just Jap Cooling-pro Skyline ECR33 (CPRO40mmRAD-ECR33) $329.oo. They have a 60mm as well but I was advised against it as it was suited more for a dedicated track car and it would have to go in without the shroud in place. I also bought a 7inch thermo fan for the auto cooler (Thermofan-7inch) $50.oo.With freight to the door it was $429.oo. Now when I go up the range the water temp is about 30deg lower the engine oil is about 15deg lower and the auto is about 20deg cooler. Temps were done using one of those laser heat guns tested before and after the upgrade.
Best money I have spent in a while. I will just have to see what winter brings and I will cross that bridge when I get there.
  • Replies 43
Posted Images
Mine started to heat up especially with A/C turned on or on dyno.
Ebay alum. asi performance 52mm $199 delivered!
Sits at 84-85'c with A/C on, boosting and Qld summer.
### p.s. guage didn't move from 1/2 even at 99'c!!! ###
Edited by RED513
i got a new clutch assembly for the fan and that will be going in this weekend, the car has been staying cool while driving but i haven't had it stationary and idling yet which is when it heats up, fingers crossed the clutch assembly will get me out of trouble.
I will keep you updated
Problem solved guys, it was my clutch assembly for the fan, put on a new one, went for a drive and idled it with air con on and never went past half way. Many thanks for opinions and help, appreciate it.
  • 3 weeks later...
Nice... please tell me where I can find an alloy radiator with the auto trans heat exchanger in the bottom!!
I allways wonder how people with Auto stags go upgrading their radiators....
Half the reason of the bottom tank for the trans auto fluid is to heat it up when the cars cold to get it to running temps. In the winter months with only a transcooler it shall be interesting.
Stags only lock up the transfer and go into overdrive once the trans oil temp reaches a certain temp so yeah it will be interesting.
Also touch wood but im in SA and have had some very hot 40+ degree days and sitting in start stop traffic with aircon cranking and my needle never moves. sits prob 1/5th below half all the time. Stock radiator with a FMIC and PWR V8 trans cooler.
you're not looking at your stock water temp gauge are you? those bastards lie... i think it was QWK32 who was telling me that there's 2 temp sensors in the stag, one for the ecu and the other for the standard water gauge. an aftermarket sensor + gauge will tell you much more than the standard gauge will.
I just had my Stageas top tank replaced and radiator flushed. As it had a tiny leak.
Quoted $300 drive in drive out, done under warranty :laugh:
Cool... I have heard under $200 for top tank replace; I don't know if this includes a core clean or not (a 'flush' could mean they just let the coolant out and replace it... however that does mean another $50+ for new (decent) coolant) or whether it means I have to take the radiator to them. I assume I do.
But the standard core is only 16mm thick FFS. I don't want to spend at least half the cost of an alloy radiator on an old core, to end up with stupid plastic end tanks again, and a 16mm thick radiator which is only going to fail again in 6 months.
Trouble is I've been having a hell of a time finding any kind of aftermarket radiator which is thicker than 16mm and has the auto trans cooler/warmer built into the bottom, for under $1,000. So I don't know what to do.
i was quoted $120 for new top o ring and flush, $180 for new top tank and flush and o ring
and flush was geting the core rodded = definitely removing the shit in there
no worries, just give them a call, probs best to tell them its an auto skyline is prob the easiest
also, that price was for me removing the rad myself and not including the coolant i'll need later
i went for a 40mm cooling pro one but i've got a manual
you could get an r31 one cheap and they are thicker and come in auto but have a different top mount but you could fab something
For interest I was quoted $190 if I dropped the radiator off, and they cleaned it out and new top tank.
I would have prefered an alloy one, but cheap alloy auto tanks are hard to find and this was covered by warranty anyway.
Interesting thanks Brendan. I'll try to get a hold of a whole radiator tomorrow as now with mine out the core looks stuffed.
On a side note... doesn't it suck how much coolant is lost when you open the cooling system (and you can't be bothered putting it on stands and collecting it with a bunch of clean containers the right size that you don't have, and re-using it... I never can bring myself to reuse coolant... looks so nasty)
the 31 rad could prob be made to fit but i'm not sure if the bottom has pegs, the dimensions of the core are fine and the hose exits are in the same place
maybe get a manual rad and an oil cooler and mount the cooler behind the rad = hot air onto it which will stabilise the temps a bit quicker
  • 3 months later...
I am having the same old over heating issues on my S1 stag as well. I am booked in for a radiator clean. I also want to replace the clutch fan. I had one on order at super cheap but they called today and said they cant get them in.
so, does anyone know where i can buy a new clutch fan assembly?? I have also tried burson's and auto pro on the coast.
Cheers
Adam
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
