once again, these are up for sale. got hella interest. but no ones fronted the cash (most promising offer would make most lowballers cringe).
work mesh, 17x8 +5 and 17x9 +11. fronts are straight 5x114, rears are multifit 4/5x114.
bit of kerbage on them, but you have to be looking pretty close. the worst of them was one of the 9's which had a slight dent in the outer hoop which has recently been repaired.
and some of the clearcoat is starting to peel around the hubs, but overall, theyre in pretty rad condition.
taking offers around $1500 without tyres. offers lower than $1400 will be laughed at, and responded to in kind.
contact me (dave) on here or on 0408961657.
can send interstate if needed, but id rather not.
if you dont shit me off within 4 seconds, i might even be able to arrange a payment plan.
https://www.sau.com.au/forums/topic/300557-sa-17-inch-work-mesh-wheels/
ugh, bump again. gotta be some interest out there.
What rubber is on them ? Brand/sizes ? Just to get this right........ +5 multi stud on rear ? SO +11 BEING THE 9" and larger width wheel,
is on front ? Cheers MIKE
i got interest in the bump photo bro :rofl: haha what other wheels you bought?
lol, f**kin rad bump pic eh?
havent bought wheels yet. but im looking at cts's, 17 x 9.5 +15 all round.
225/45/17 Kumho Ku36's on the front (f**kin sticky), and 215/45/17 Kumho Ku25's on the rear.
the fronts are 17x8 +5, rears are multistud's and 17x9 +11.
ive had about a half a dozen people say that, and my reply has been the following.
im not splitting. you either buy all 4, or you dont buy them at all.
Why not say, sure, for $1500 and I'll chuck in two fronts for zip!
:banana:
If I had $1500 blowing a hole in my pocket I'd snap em up (too bad I'm post-wedding broke ATM)
lol then if you wont split, you never gonna sell these wheels, well njot at that price, i just bought a full set that had just been re rolled and polished with tires for $900...
lol, ive said that once aswell.
sounds like your polishing more than your wheels there frenchy
bump to the top for some tough,well priced rims and tyres
deposit received.
... you were saying?
:D
  • 1 year later...
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
