Got Ow3ed something hardcore by a Blue S15 trial body kit, 19's and one nicely worked engine, running 16psi apparently but had external wastegate so not running stock turbos very nice indeed, and great guys too.
Just quickly-you wouldn't happen to own a white R34 GT-T like your avatar photo,wouldya? Coz I spotted a neat car as per described,and parked next to it,at the Shell servo' in Fyshwick this afternoon...and there was a gunmetal grey R33 GTS(T?) parked the other side of the servo,too.
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1176949
I spotted that Blue S15 once, does it have chrome windscreen wipers or something? Only thing i can fault it for :rant:. he was having a squirt against some guy in a REX in tuggers from the lights to the form one lane infront of the shops. He won, car sounded wicked too.
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1177875
saw a burgandy r33 in dickson had like black/carbon fibre inserts were the rear lights are you know like that triangle thing :rant: it had gtr badges though i dont think it was. had gtr front bar not sure of the side skirts and had a super dupper rear wing.
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1178717
spotted 1 silver stagea rs4 at autotech today with a bloke holding a unichip shitting in it. terminal, that yours??
also, a stock-looking black 33 with an obscenely loud and horrible sounding exh. drive past subway in fishies. if thats anyone here, please change it. it sounded like a carby lancer with a cannon!!! *cringe*
d
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1178736
you had me worried it was me ;) but i havent been to fyswick in ages so i am safe :D
also would have to agree funniest miss spelt word ever ;):)
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1179505
spotted 1 silver stagea rs4 at autotech today with a bloke holding a unichip shitting in it. d
Yepp, that was my beast :)
Unichip didn't go in cause they were having problems locating the wire for the TPS. This is sort of a blessing, cause I was playing with the TPS and trying to find the wire on the ECU for it. Found the wire and I also found out why I get a slight flat spot when it's cold... The TPS needed adjusting, now it's all good and not giving false readings when cold (that's why that couldn't find the output) I'll go back out there tomorrow and tell them.
J
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1179734
Yet?
Joining me and jay in the unichip fraternity at some stage?
LOL - yepp, soon I hope !! Just had a slight delay with getting it in. APS said that I'm the first to put a Unichip and the boost control module into a Stagea, so we've had to make up our own wiring diagram etc...
I 'think' it's all good to go now.... hopfully....
J
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1179737
Soptted a R33 with Gold rims today at the chisholm round about. was in the back seat of a lancer.... gave you some looks... saw a lil smile..
Also a Maroon R33 with GTR badge in the front grill, coming out of Qbn tonight..
Was also in the lancer...
https://www.sau.com.au/forums/topic/30059-spotted/page/118/#findComment-1180328
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
